Results 1 to 12 of 12
2008 CBR 1000rr Crankshaft (HELPPPPPPPPPP)
    Newbie
    Oct 2013
    Question 2008 CBR 1000rr Crankshaft (HELPPPPPPPPPP)
    Dear All,
    Please I need your help (URGENT)
    My bike's crankshaft is totally dead and I asked a lot of dealers concerning 2008 or 2009 crankshaft but they all replied that they don’t have it anymore.
    The question is: can I buy 2010 crankshaft and install it in my 2008 engine?
    Awaiting your reply as soon as possible.
    Thank You for your concern
    Wirelessly posted
    What do you mean by "dead". You may need more than a crankshaft.
    You would be better off just replacing the engine.
    Newbie
    Oct 2013
    Re: 2008 CBR 1000rr Crankshaft (HELPPPPPPPPPP)
    i mean, it is broken and can't be used again. i just want to replace it with 2010 crankshaft.
    is that Possible ?
    Newbie
    Oct 2013
    Any help my Friends ?????
    Raymond NH
    The 13310-MFL-020 crankshaft is listed for both 2008 and 2010 engines. Should work fine. That said, Partzilla seems to have the other 2008 code in stock: http://www.partzilla.com/parts/detai...0-MFL-010.html too, so if you are really concerned, you could simply order a 13310-MFL-010 from them.
    Its...not as easy as a Replacement part. And I am sure more is going to need replacing so you may just want to look for another motor
    Jun 2005
    You'll also need to set the bearing clearances since your old cases are matched to your old crank. The new crank is going to need new bearing caps and the only way to know what size is to measure it. Sorry if I sound like a dick, but based on your question it doesn't sound like you're equipped to do that. It's not rocket surgery, but you've got some homework to do.
    Newbie
    Oct 2013
    Dear All,
    Thank you very much for your help ,,, really I have known a lot from all of you.
    I will go through the Manual Service and do my homework.
    I went through this website http://www.motorcyclegoodies.com/oem...nkshaft-piston and i found the most updated crankshaft for the CBR1000 Model 2008.
    Really, I love this beast very much. It is very light and strong.
    I love My Bike and I know that I will pay too much but he deserves the cash.
    My bike's name is BIANCO VOLPE and I am from Egypt.
    Again, Thank you all very much and please keep in touch.
    Newbie
    Oct 2013
    hallo my freind,
    The crankshaft that you mentioned is the old one and the new crank code is 13310-MFL-030 ,,,, THANK YOU
    Meriden, Ct
    Que total engine failure in 3...2...1...
    You may be able to get around measuring the diameters on the new crank v. the old with precision gauges by using a plastiguage and determining the clearances between the mating components that way. http://www.plastigaugeusa.com/how.html
    I'm thinking if he can't find a crank, splitting the cases and verifying bearing clearances may be challenging. Has anybody else suggested this??
  1. Replies: 3
    Last Post: 06-24-16, 12:22 AM
  2. Normal running crankshaft direction
    By Punjistick in forum Bike Maintenance
    Last Post: 04-15-13, 05:19 PM
  3. 2008+ Honda CBR 1000RR Front Calipers
    By SAB in forum Wanted
    Last Post: 09-06-12, 01:25 PM
  4. New to the site, just picked up a leftover 2008 1000rr.
    By RRmatt in forum General Bike Related
    Last Post: 03-02-10, 02:12 PM
  5. New 1000RR is up
    Last Post: 10-03-07, 06:15 AM
