Results 1 to 6 of 6
No Neutral
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    No Neutral
    Ok, lets hear from the more technically proficient than me:
    Single sided swing arm with a reverse threaded big nut to hold the rear wheel on. Had to repack/check the rear bearings over the winter and that nut was STUCK. Anyway in getting it off i had spun the rear wheel 4-5 complete rotations while in gear with a breaker bar. Fast forward to yesterday when I took the bike out of my workshop and transferred it to my 1/2 garage to get ready to re-register it and ride and I cant get it to go into neutral. I rode it down my street in 1st and 2nd gear no problem and it sounds fine(no unusual noises). I can also shift between all gears standing still with the engine running but I cannot find neutral at all and I don't even see the green dash light flicker as I go by where I think it should be. It has been mentioned on an MV specific forum that I may have bent a shift fork/rod - and I plan on contacting Eastern Cycles in Beverly this morning, but am looking for any advice. I was hoping everything might re-position itself if I took it for an at speed ride up the highway, but also don't want to further damage anything.
    Wirelessly posted
    Duc 749/999 03/04?
    Bleed the master.
    7mm nut inside the clutch master open it a crack and watch for an air bubble.
    Jul 2008
    Massachusetts
    Re: No Neutral
    mv agusta - still the same?
    Wirelessly posted
    I believe so.
    Its hydraulic clutch related.
    Senior Member korndogg's Avatar
    Milton VT
    Re: No Neutral
    With the key on, but the motor not running, you should still be able to find neutral and see the N light flicker if it were a clutch problem. Doesn't sound like a clutch issue to me.
    Next time use the rear brake instead of the transmission..
    Tommy R.
    '06 GSXR 1000
    '03 FZ1
    Jul 2008
    Massachusetts
    Re: No Neutral
    Yeah live and learn. Unfortunately my learning tends to be expensive...
  1. FZ6 stuck in neutral?
    By Beam in forum Bike Maintenance
    Last Post: 06-23-14, 11:48 PM
  2. Wont stay in neutral?
    By Sqzeplay74 in forum Bike Maintenance
    Last Post: 05-28-12, 11:04 AM
  3. Do you shift into Neutral at red lights?
    By mace in forum General Bike Related
    Last Post: 03-04-12, 01:05 PM
  4. Finding neutral
    Last Post: 06-30-11, 03:23 PM
  5. Rpm's = acceleration false neutral ???
    By sluggah in forum Bike Maintenance
    Last Post: 08-11-10, 06:43 PM
