Where do you guys suggest to buy the NGK Iridium plus for my bike part#CR9EIX, I called autozone they didn't have them and pepboys couldn't locate them by that part#, he wanted to take the plug out and he will match it up![]()
dont even waste your time for bike plugs at places like autozone and pepboys. best bet would be to go to motorcycle shop or more likely a suzuki dealer. If you can find a place on line thats cheaper. more power to you.
those guys are idiots if they cant look in a book with the NGK # you gave them. motorcycle shop is your best bet. prolly $9 each too
Bikebandit.com
1993 Honda CBR900RR
1990 Suzuki GSXR1100
1992 Kawasaki ZX750
1996 Honda F3 Trackbike
I picked up a set of NGKs (CR9EK) for $8 each at Greater Boston Motorsports. Bikebandit wants $9. Not including shipping. When I opened the box to look at one of them, I had to laugh. Theyre so TINY! They look like a plug youd put in a lawn mower instead of a 900CC engine. No, wait....the mower plug is bigger!
sparkplugs.com too
I bought mine at Performance Cycles in Shrewsbury yesterday, damn expensive though at $10 a piece. Hopefully the iridiums are all that they're supposed to be for that price
I went to a napa first when I needed to get some. They didnt have them but they told me they could have them in a couple of days. I didnt end up getting them there because Im the kind of person that wants them now but if I remember correctly they were also the cheapest where the bike shop was the most expensive.
Denniskirk.com or other online stores, but they charge shipping, unless you buy $100 worth of stuff.
ZX10R
Ned
the stealership no way![]()
I always get my plugs from auto parts store!
Even suk twin tip tl plugs.
www.bostonmoto.com
Forum Rules
Big spark plugs just waste valve area.. that's why it's small, better performance.
Check out this comparison:
That's an F1 plug on the left.
What benefit do the irridium plugs give? Sorry for the n00b question...
"Harley Davidson: The most efficient way to turn fuel into noise without the risk of power and handling."
Selltekk.
-'04 Yami YZF600R (NOT R6)
- Uberfast Blue color
-Two Bros. Exhaust
-OES Sliders
-Helibars
-Mototeck Flushies
-Factory Pro Shift Kit
<a href="http://www.linkedin.com/in/davefortin" ><img src="http://www.linkedin.com/img/webpromo/btn_viewmy_160x25.gif" width="160" height="25" border="0" alt="View David Fortin's profile on LinkedIn"></a>
Iridium plugs are more efficient. Its a durable hard precious metal with a much higher melting point then platinium, nickel, gold, and silver. Its a harder metal then the others. To sum it up, they are a higher quality plug.
Advantages:
due to the properties of Iridium, the spark plugs centre electrode can be made with a much smaller diameter than with platinum, Gold or gold palladium and copper/nickel types without sacrificing service life. The spark plugs potential difference is more concentrated at the tiny Iridium tip and hence less 'spark jump' voltage is required - this can be as much as 5,000 volts less than with standard plug types. Ignition is improved and less strain is placed on the ignition system. Benefits of improved ignition/combustion include better fuel economy, increased power/acceleration and especially better throttle response.![]()
NAPA. for sure. usually bike shops will charge 8-9 bucks a plug. just picked up plugs from napa. ngk's... and an oil filter for $18 bucks.. 4 plugs and a filter. great price.
Cool! Thanks for the info.
Selltekk.
-Two Bros. Exhaust
-OES Sliders
-Helibars
-Mototeck Flushies
