Results 1 to 11 of 11
noob question: wire work for trackday/race
    May 2010
    Captial Region, NY
    Is it really as simple as taking the bolts/nuts out, drilling it, put it back in and wire it to LRRS/CCS rule? Or this is something that needs to be done with a special technique?
    Thanks.
    High maintenance priss
    Central MA
    Re: noob question: wire work for trackday/race
    Quote Originally Posted by RocketPunch View Post
    Thanks.
    Technique is important; probably most important is pulling wire in the fastener's tightening direction.
    There was a recent thread w/ pictures by Pigman...hold on, I'll find it.
    Central MA
    May 2010
    Captial Region, NY
    Thanks.
    So the drilling part is as simple as using the right size drill bit and drilling it, right?
    Central MA
    Thanks.
    1/16" drill bits. "Bits", because you will destroy them quickly...especially as you learn. Don't need fancy ones, regular HSS is fine. Once you know what you're doing you should be able to drill multiple parts easily w/ a single bit. If you're going thru 1 bit per part, you're doing something wrong.
    General drilling tips:
    Center punch before drilling. Always.
    Drill press helps a ton, electric hand drill will work
    Use a cutting fluid
    Drilling jigs not necessary, but vise probably is.
    Some bolts can be drilled on the bike; on the bench is more betterer
    If drilling threaded part, use a junk bolt or nut to help prevent damage to threads
    Have a 1/16" punch & hammer so you can push the inevitable broken bits out of the part you're trying to drill
    A 6-pack of your favorite brew.
    Good luck!
    Lifer eboos's Avatar
    Here's a tip, use a 5/64" (2mm) bit instead of a 1/16". It doesn't appear to be much larger, but it is by 25%. The bit will last a hell of a lot longer and ease your frustration.
    May 2010
    Captial Region, NY
    Use a cutting fluid
    Good luck!
    That's gold, Jerry! GOLD!
    Find a drill press. Don't waste your time or money.
    May 2010
    Captial Region, NY
    Quote Originally Posted by eboos View Post
    Thanks!
    Lifer CMG241's Avatar
    Windham, NH
    Thanks.
    no its not easy,it can be frustrating
    absolutely - just got lot less frustrating
    bingo.
    or be lazy and buy pre-drilled bolts like i did
  1. Noob question re: race license and ccs races
    By soofle616 in forum Pit Area
    Last Post: 07-05-13, 12:22 PM
  2. '06 SV650S Noob bolt question
    By DroFiveOh in forum Bike Maintenance
    Last Post: 06-20-12, 02:20 PM
  3. SV Safety Wire Question
    By HanktheTank in forum Bike Maintenance
    Last Post: 08-01-11, 12:21 AM
  4. safety wire question(s)>
    By s a x m a n in forum Pit Area
    Last Post: 04-24-06, 09:32 PM
