Results 1 to 20 of 20
Seized Steering Stem Nut
    Hey everyone,
    Nearly set after my crash about a month ago, but this one nut is stuck on the top of the steering stem and won't budge! I have used WD-40 for like 2 days straight now but it makes no difference. I think my next move is to try and heat it with a blowtorch, because it feels like there is no give in the thing. Anybody have any tips or tricks for me on getting a seized nut off?
    thanks,
    Pat
    Re: Seized Steering Stem Nut
    did you loosen the pinch bolt?
    Lancaster
    impact?
    Corey
    Lifer Danz19899's Avatar
    Grafton, Ma
    good impact gun and a 6 point socket should help. but if thats not quite enough heat helps a bit too
    www.bostonmoto.com
    Ride to live, live to ride
    Sorry I forgot to mention,
    This is on an 84 vf500f, I don't think there is a pinch bolt. There is pretty much just a big 29-30mm nut that is just completely stuck on this thing. Went out and bought an adjustable wrench for it today, but no dice. I'm goin back to see if I can get a socket this big.
    Lifer JettaJayGLS's Avatar
    Tahoe City
    PB blaster...works 20x better than wd-40 for loosening bolts.
    If that doesn't work, heat and a breaker bar should do the trick.
    Grafton, Ma
    ya definitely get a socket and breaker bar. sometimes it does take impact tho. find a buddy with an impact gun works 10x better at breaking shit loose. got a set of large sockets at sears for like $40 think its got 27-36mm
    www.bostonmoto.com
    Banned G21forme's Avatar
    Lakes
    If you are just using a socket wrench it's not going to budge, I've put scott't dampers on my gsxr,zx6r, and Lauren's R6 and the nuts had been torqued to the max. Try a breaker bar and a friend to hold the bars and +1 on the PB blaster.
    Jan 2009
    Waltham
    Wirelessly posted (Tilt: HTC-ST7377/1.59.502.3 (67150) Opera/9.50 (Windows NT 5.1; U; en))
    Am I the only one who calls it a cheater bar instead of breaker? Sorry no input here.
    Lakes
    Quote Originally Posted by WordTooYoMamma View Post
    If I had your gut to use as leverage I wouldn't need a breaker either
    I'm wirey
    Whu??? aren't the torque values for these nuts are usually like 12-17 foot lbs. Why the hell are they being torqued down like that?
    The way I understand it, that nut simply holds it flush with the steering stem adjuster bolts that lie under the triple clamp. Then you've got the pinch bolts for the fork tubes....
    There's no real need to crank that mutha down, is there?
    Lifer ZX-12R's Avatar
    Candia, NH
    A cheater bar is what you use on the end of a breaker bar to get even more leverage.
    An impact wrench should make short work of the stem nut.
    Lifer DuncanMoto's Avatar
    PB Blaster. WD-40 is not a rust buster like PB is.
    PB leave for a day, pb again, heat with propane only and as it loosens retighten it and loosen more.
    That way you won't completely ruin the threads.
    yep... these are definitely not supposed to be cranked down!!!
    In general, there is a nut below that is supposed to actually hold the upper and lower bearings together (and even that doesn't need crazy torque as it has a lock washer to hold it).
    The big nut on top only holds the triple tree (which is also held by the forks)
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Lifer Currently's Avatar
    Ooltewah, TN
    Red loctite?
    Why someone would use it for this purpose is beyond me.
    If loud pipes save lives, imagine what learning to ride would do.
    Just Registered Doc's Avatar
    Jericho, VT
    I have the socket and a cheater bar... Come see me AGAIN.
    Wirelessly posted (BlackBerry Giggity: Mozilla/5.0 (iPod; U; CPU iPhone OS 3_1_2 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7D11 Safari/528.16)
    Quote Originally Posted by Paul_E_D
    The torque for the GSX-R is 76.5
    live to ride seth399's Avatar
    Feb 2007
    CA
    ya the nut on top usually calls for a good amount of torque. Its the pinch bolts that you don't want to torque down much (on the triple clamps) those are more like 15-20 ft/lbs
    LRRS #399
    MX #505
    Oh yea. I thought they were referring to the yoke nut. The side ones are 16.5 ft/lbs on a GSX-R
  1. Replies: 6
    Last Post: 09-21-16, 10:05 AM
  2. WTB: Sport bike steering stem stand
    By Garrett in forum Wanted
    Last Post: 07-15-13, 04:07 PM
  3. How To : Steering Stem Droid Mount/ Ball Mount for GPS
    By importcustomx in forum General Bike Related
    Last Post: 07-02-12, 10:37 PM
  4. steering stem
    By frenchy21 in forum Wanted
    Last Post: 08-11-11, 09:33 AM
  5. Steering Stem Socket - 02 VFR800
    By VinceF2 in forum Bike Maintenance
    Last Post: 03-08-11, 09:22 AM
