Results 1 to 8 of 8
track/wheel alignment
    Raymond NH
    What's the most foolproof way to check the alignment of the rear wheel? I spooned on a new tire last night and noticed the old tire was worn a little funny just off center. Thinking the rear wheel might be skewed a bit.
    Take a piece of string and mark it exactly halfway down it's lenght. Sit at the front of the bike and pass a piece of string from the front, round the back wheel halfway up the tire and back to the front of the bike. Pull the two ends of the string to take any elasticity out of them and keep the ends even with each other. The marked piece should be in the center of the rear tire.
    Alternatively, you could use the marks on the swingarm. That's what I do, and although people say that they are not accurate, I have never had a problem. I only use my tires for 100 miles or so anyway.
    Degs
    Northshore/Beverly, MA
    Measure the distance from the centerline of the swingarm to the center of the rear axle. (this is if you don't have anything in the way....) You can make up a device that has 2 cones on a slider, that works well too. Also visually, check the chain on the rear sprocket. spin the rear wheel, and adjust until the chain is centered on the sprocket....
    Lifer legalspeed's Avatar
    Somersworth, NH
    Mark:
    Make us one.
    Please. I've seen easy ones with a rod and two clampy things; you move one of the clampy things and check it against the other side.
    LRRS\CCS\WERA #486
    Originally posted by legalspeed
    Mark:
    Make us one.
    I should huh?
    Lemme see if a can work something out....This is also gonna be a back burner job...with all the other crap I want to build....
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    the mark please build me list....
    TLRman please build me... ...
    chain break/rivet tool....... brent
    tire thingy with cones....... legal speed
    <add your name and thingy here>
    Raymond NH
    Cheers.
    I checked it (roughly) this morning and found the alignment out 1.5 mm at the axle. I suspect that's a lot and am perplexed at how I let that happen
    Member NHViffer's Avatar
    Oct 2002
    Manch-Vegas
    On the street, your tires should wear off to one side (left, I think). This is because roads are typically crowned in the center for water run-off... I know people who do a lot of touring miles that have this happen. Of course my tires wear mostly at the edges...It's my story and I'll tell it the way I want!
    Tim B.
    Manchester, NH
    2002 Triumph Daytona 955i
    CSBA #256
    www.christiansportbike.com
    Jesus Rocks!
  1. Alignment after chain adjustment
    By Drewski in forum Bike Maintenance
    Last Post: 08-03-16, 06:21 PM
  2. Rear wheel alignment
    By SRTie4k in forum Bike Maintenance
    Last Post: 05-22-15, 08:53 AM
  3. Lionel's Wheel Alignment (C Street, Nashua, NH)
    By butcher bergs in forum Business & Product Reviews
    Last Post: 07-23-09, 09:36 PM
  4. Yamaha FZ1 Fork Alignment....
    Last Post: 07-02-05, 07:00 PM
