Results 1 to 14 of 14
Plug broken off in head. Great.
    Sep 2007
    Middlebury VT
    Unhappy Plug broken off in head. Great.
    Cylinder #1's plug broke at the gasket ring leaving behind the plug's threads in the head.
    The center electrode is still attached and a set of easy outs will soon be put to the test.
    I have used spark plug anti-seize since I was 6 years old on all my machines this, bike included.
    I'm speculating that perhaps the plug was a bit weak or that my spark plug socket was not sitting flush
    as I started to put pressure on it for removal.
    My first time working on this conundrum may have varied results.
    The damaged plug has perfect color and all 16 valves were good to go with no adjustments needed as they all were sitting between the upper and lower clearance specs.
    I have drizzled penetrating fluid onto the NGK's threads that now sit awaiting their fate with a tool I wish I didn't need to use.
    It looks like this.
    http://www.brokensparkplug.com/image...20100_9981.JPG
    Oh well, old bike.
    Waterbury, VT
    Re: Plug broken off in head. Great.
    It sounds like the mechanical Gods needed to test you... Good luck with the EZ Out.
    SSearchVT
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Make sure you account for ALL pieces
    Or be real and pull the head
    Glen Beck is John the Baptist
    Sep 2007
    Middlebury VT
    I'm hoping to not have to pull the head off the old girl.
    I can only imagine what condition the header bolts are in.
    I'll keep you posted just the same though.
    Dec 2005
    Near The Dragon
    use a highly rated penetrant.. cyclo's 'break away' or castle's 'thrust' are both excellent.
    i take it the gasket surface is at the break line in the picture?
    and what the hell dinosaur is that plug for?!
    Get out while you can
    Find your own path
    Sep 2007
    Middlebury VT
    The picture is only an example of what I have on the workbench.
    The insulator and plug tip came out as one piece and all that sits in the head is the plug's thread portion with the grounding electrode still attached.
    I'll post up my own pictures today or tomorrow.
    Jun 2005
    Sounds like a good time. Good luck, man.
    Sep 2007
    Middlebury VT
    My friend just called to let me know he dropped the easy-out kit in my mailbox at home.
    He was mentioning that some co-workers have had good luck using this tool to do this particular job. I hope the tools come blessed.
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    i had this happen once. big EZ out duct taped to a long extension and a wrench and it came out
    -Benjamin Franklin
    Aug 2004
    Baltic,CT
    Tap while applying turning force
    Also maybe SOME heat with a propane torch...piston down
    Aluminum expands more than steel
    propane hot enough to melt aluminum heat cycles also good for getting penatrating lube to seep into joint
    Dec 2005
    Near The Dragon
    ok, am i haveing some kind of weird psychedelic dream, or was this thread actually resolved and the broken part already came out..
    or did i just dream that and think it was real?..
    very confused..
    Find your own path
    May 2007
    Southern NH
    Quote Originally Posted by Cerberus View Post
    very confused..
    He started a new thread...not sure why! Alls well that ends well though...
    http://www.nestreetriders.com/forum/...lug-fixed.html
    Muhammad Ali.
    Sep 2007
    Middlebury VT
    Wupps. The excitement of removing the broken plug must have gotten the better of me.
    Dec 2005
    Near The Dragon
    *phew*
    i thought for a second there i was going to have to cut back on the drinking..
    Find your own path
  1. Great Ride Sat with great friends
    By GingahNinjah in forum General Bike Related
    Last Post: 05-21-12, 06:26 PM
  2. Picture of broken plug removed from head.
    By Ericthejet in forum General Bike Related
    Last Post: 11-03-09, 09:56 AM
  3. Cylinder #1 broken spark plug fixed!
    By Ericthejet in forum Bike Maintenance
    Last Post: 03-16-09, 06:07 PM
  4. Great Head....... ers
    Last Post: 02-27-08, 08:31 AM
  5. How to plug?
    Last Post: 04-29-05, 08:47 PM
