Results 1 to 8 of 8
Paint: Rattle-can match?
    Whenever I paint something with a rattle-can, I always put a clear coat over it. Acrylic-Lacquer normally. Buffs out nice.
    The thing is, is if I use it over a black paint... say DupliColor Automotive Acrylic-Lacquer.... It almost dulls the black to a grayish/yellowish tinge in the clear-coat, rather than a crystal clear like, say a factory paint job.
    It's really hard to describe without seeing it in person... and black is super hard to match (almost harder then red) when it comes to manufacturer/paint company.
    Has anyone had any good luck with off-the-shelf paint? I'm just hoping I'm using a crappy brand, and I want to get a good result before attacking some fairing pieces on my bike.
    Thanks in advance!
    Jun 2005
    Re: Paint: Rattle-can match?
    I've never had very good luck with Duplicolor, to be honest. I eventually just broke down and went HVLP. Much better, but not really convenient.
    Some Auto paint suppliers can mix and fill rattle bombs for you. It's easiest if you have a paint code they can use.
    As far as clear goes, I haven't used it, but this stuff seems to be the best in a rattle can:
    http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
    Wear a respirator (not a dust mask) if you get into the auto stuff...
    i know of two ppg paint shops that can color match and put it in spray can for you
    All strippers SHOULD have fake tits!
    Nov 2008
    Framingham, MA
    Not sure if you looking, however, Custom Aerosols & Paint Supply (978-840-4476) in Leominster will mix any color paint and put it into aerosols for you.
    some of them have spectrometers too, they can match anything even faded factory paint
    I did some touch up once on my SV tank when I had well over 100k, went to a local auto paint store (Sanel)with my tank , the put the spctrometer on it, mixed me rattle can can of base, also picked up rattle can of clear coat
    "Plymouth's Fastest" BrianC's Avatar
    Sep 2010
    Plymouth, MA
    www.colorrite.com has factory matched paint available in rattle-cans, and they have their clearcoat in a rattle-can too. Kind of expensive but I used their Yamaha blue on my bike and it came out pretty damn near a perfect match.
    LRRS am #121
    Thanks for the help guys! I may just break down, get custom mixed paint in a can, and pick up a cheap spray setup for my compressor.
    I think the chemicals they use to keep the paint aerosol are what attribute to the yellowing in the clear-coats.
    I'll be in contact with that place in Leominster!
    Senior Member klepsta's Avatar
    Feb 2008
    Stoneham
    Sherwin Williams Auto Paints in Medford will mix any color in a rattle can for you also. They also carry the 2K clear coat (catalyzed clear) which works very very well, and pretty much any other supplies you need for a complete paint job.
    Steve
    Work Hard---Play Harder
  1. Finishing rattle can paint
    By Garandman in forum Bike Maintenance
    Last Post: 05-25-19, 05:09 PM
  2. Rattle can paint job
    By 01xj in forum General Bike Related
    Last Post: 04-20-18, 12:19 PM
  3. question for rattle can paint pro's.
    By boosten lebaron in forum General Bike Related
    Last Post: 07-08-13, 06:50 AM
  4. Rattle can paint suggestions
    By intergalactic in forum General Bike Related
    Last Post: 03-26-10, 05:28 AM
  5. The No Paint Match Blues
    By Zap in forum General Bike Related
    Last Post: 04-18-04, 09:06 PM
