Results 1 to 8 of 8
brakes
    Lifer Wishbone's Avatar
    Jul 2006
    brakes
    so i upgraded the fizza with a brembo master from a 916 stainless lines and new pads
    the problem is i can't seem to plumb the damn thing
    i have pumped the lever a few thousand times do as you would to bleed the brakes normally and even tried to suck the fluid threw
    am i missing something or does it take a year or two to get the fluid to move the pistons?????????
    Lifer union's Avatar
    Blackstone, MA
    brakes
    Leak in the system somewhere?
    James
    Jul 2006
    brakes
    dunno the banjo bolts and copper washers are all new also
    Senior Member LiononaLeash's Avatar
    Oct 2005
    brakes
    You have air in the lines still... not just a little... you have ALOT of air in the lines.
    I usually fill the master cylinder with fluid and use a shop-vac to pull the fluid down through the calipers. It works better than a mighty vac.
    Brakes are rock solid.
    and yes, with the system empty and the pistons all pushed in, it takes several squeezes of the brake lever to get them to come back out to move the pads to the rotors.
    Jul 2006
    brakes
    ok so maybe im slow, how in the hell are you supposed to use a shop vac????????????????
    Jul 2006
    brakes
    well? bob that was directed at you
    Senior Member nerijusj's Avatar
    Somerville, MA
    brakes
    When you bled your brakes you tightened the bleeder valve each time before letting the lever go back to it's normal position right? Otherwise you'll suck air right back into the lines.
    ZX10R
    Ned
    Feb 2007
    Westborough
    brakes
    If a Mity Vac is not working, move the Calipers around while tapping them lightly.........like your burping a baby. You should be able to see air bubbles in the reservoir
    I've heard some guys use rubber bands and keep lever pressure over night.
  1. New Brakes
    By Legion1440 in forum Bike Maintenance
    Last Post: 03-22-10, 10:09 AM
  2. KTM brakes
    By MysteriousR1 in forum General Bike Related
    Last Post: 01-23-10, 07:39 PM
  3. Brakes help
    By HBerry in forum Bike Maintenance
    Last Post: 06-23-08, 02:33 PM
  4. New Brakes
    By alwyzbroke in forum Bike Maintenance
    Last Post: 10-30-07, 08:14 PM
  5. Brakes
    Last Post: 06-30-05, 08:19 AM
