Results 1 to 12 of 12
license plate light instal?
    Sep 2007
    Middlebury VT
    Question license plate light instal?
    1984 Ninja 900
    Bike has long ago lost it's white plate light.
    Will be getting a VT inspection in a few weeks and for the trouble I am going to install one.
    It has 2 wires. I imagine one would be ground and the other to 12v?
    I'll splice one into the 12v leading to the taillights and the other ground and I should be good to go?
    Thanks
    Just Registered kermita's Avatar
    Mar 2007
    RI
    Re: license plate light instal?
    Quote Originally Posted by Ericthejet View Post
    1984 Ninja 900
    Thanks
    Is the tail light close enough that if you drilled some holes in the bottom of it, it would cast light on the plate? I've done that before and it worked fine. Just drill the holes close to where the bulbs are and it should get a decent amount of light on the plate. If that's not an option I'm clueless when it comes to electrical.
    -kim
    drz400sm
    http://farm3.static.flickr.com/2473/3532494258_79ceb54614.jpg
    Member Benyen Soljax's Avatar
    Raymond, NH
    1984 Ninja 900
    Thanks
    you got it on the nose. i wouldnt worry too much about the wiring though (as long as u got a 12v and gnd). splicing the wires and miswiring the plate bulb wont hurt much, in fact, the bulb will prolly still work, the current will just be going the wrong direction through the bulb. again, not a big issue.
    if your plate is close enough i would try to bum light off the taillight though. you can dremel out a section to cast light on the plate then epoxy a piece of clear plastic from a CD case over the hole to keep the water out. works like a charm unless the plate is set too far back or the lights are weird shapes.
    Sep 2007
    Middlebury VT
    The idea for holes in the t-light might actually work.
    I'll get back to you on that one.
    Waterbury, VT
    With a test light it is easy enough to figure out which is the 12V and which is the ground. If you go with an incandescent bulb - it really won't matter, but if you go with an LED like this one:
    TARGA LED LICENSE PLATE LIGHT - WHITE LED - Targa
    you need to have the current going in the right direction. Simple enough to do - if you're in the Waterbury area shoot me a PM, and I'll help you out. Good luck
    SSearchVT
    Newbie StarJunor's Avatar
    Feb 2008
    Quincy MA
    I have the same one and like it very much. Very clean I would go with that one.
    Sep 2007
    Middlebury VT
    Thanks again for all the advice.
    Lifer Quigs's Avatar
    Feb 2002
    Just as a heads up, the frame that I linked is out of stock at tobefast.com. There are a bunch on eBay though.
    Just Registered 2OO6rr's Avatar
    Monadnock Region NH
    Does anyone have the led license plate bolts? I am looking at both the led bolts and led frame.
    Matt
    2006 CBR 600RR
    Lifer DuncanMoto's Avatar
    Quote Originally Posted by 2OO6rr View Post
    I can get you a pair of the bolts for $25 or a frame with 6" Led for $45
    $4.75 shipping gets one or both to you Saturday or Monday at the latest.
    Bolts are cool, but can break easily. The frame is a better solution as far as longevity.
    Quote Originally Posted by Benyen Soljax View Post
    One note. Unlike filament bulbs, LED bulbs can blow if you reverse the polarity.
  1. Yamaha FZR400 license plate light
    By hdscarbro in forum Wanted
    Last Post: 02-05-13, 03:38 PM
  2. FML License Plate gone
    By FZR in forum General Bike Related
    Last Post: 07-21-11, 07:47 AM
  3. LED license plate bolts
    By Twheat18 in forum For Sale
    Last Post: 09-22-10, 09:49 AM
