Results 1 to 21 of 21
proper battery charging
    anyone have experience with what happens, when you don't follow protocol?
    I got an OEM #'d battery from Autozone.
    I filled the battery with appropriate acid levels, but only waited 5 minutes (instead of 1 hour) before putting it on a battery tender. It was on the tender for a total of 30 minutes when I rolled it out of the garage and started the bike (it started just fine) and rode to Boston from the Worcester area. I let it sit outside the club for 3 hours and came back where it started just fine. I then rode back, and now it's back on the tender until I ride it again.
    Did I just drastically reduce the life of the battery?
    Even so, damn was it worth it to get out there (especially tonight)
    ...well, minus the near-low side at the mass pike entrance
    who knows
    Re: proper battery charging
    you're screwed!
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    Dude!!!
    That's like trying to stick it in without foreplay.
    You might get screwed later, but it's not a definite.
    Dec 2005
    Near The Dragon
    hard to be certain, but you'll probably be fine.
    especially since you did put it on the tender before and after the ride.
    Get out while you can
    Find your own path
    Quote Originally Posted by DuncanMoto View Post
    Dude!!!
    You don't think he got his bike preggers did he?
    Jan 2009
    Waltham
    Wirelessly posted (Tilt: HTC-ST7377/1.59.502.3 (67150) Opera/9.50 (Windows NT 5.1; U; en) UP.Link/6.3.1.20.06.3.1.20.06.3.1.20.0)
    Lubrication is for wussys
    and ted apparently
    But seriously if something says wait an hour its probally there for a reason. Sort of like why i didnt take my bike in for the break in service after 50 miles...
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Just stay on the bus routes.
    Just Registered
    Is it not obvious?
    you probably reduced it's overall capacity somewhat , but not very much.
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.0)
    The time for the acid 20 + minutes is just to give the
    Glass mat time to absorb and settle.
    Just Registered
    Is it not obvious?
    But the initial reaction causes a substantial bit of heat and outgassing, definitely do not want to apply current to cells while that's occuring or it's easy to overheat. Heat rapidly reduces a batteries ability to hold energy.
    True.
    All true.
    well, in retrospect I must've been too excited to ride, for the first time this season, that I cared
    meh...it works...I'll re-post in 2-5 years with the update
    KB KB's Avatar
    Manchester NH
    Trials tire all the way!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    well, 2 years is long enough, eh?
    here's my report:
    if I let the bike sit one month, the battery does die down. It doesn't die *completely*, it just cranks slower than usual. Problem is, she's an old girl (17 years and running!), with 40k+ miles, and the valves haven't been touched for over 32k+ miles....so while it didn't start without the battery tender on it for an hour, it's hard to say if it's the battery, or just quirks of an old bike
    I let the bike sit overnight after starting it, and the next day the battery was green and good to go
    I have one...but I rent...and no place to plug in where I park
    I have one...I wrote about it my post
    I rent...no place to plug in where I park
    Generator...hahahaha.
    Sorry my Bad.....I would just yank the battery and leave it on the charger
    After every time you use it?!
    KB KB's Avatar
    Manchester NH
    I rescind this comment.
    Trail tires can eat a bag of turkey mike dicks!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Solar cell with a float circuit, auto stores sell them for vans that sit for long periods of time. You'll need to cut the cigaret lighter plug off and either sacrifice a batt tender lead set for the plug or make your own harness. Sun is out, batt is getting juice.
    Also, find out what's causing it to drain down when the key is off, may be a short just starting to announce itself.
  1. Seeking advice on battery charging and maintaining
    By dompel in forum Bike Maintenance
    Last Post: 11-17-20, 01:50 AM
  2. Replies: 0
    Last Post: 09-23-16, 12:38 PM
  3. How do I determine if I'm over-taxing my battery/charging system?
    By jeantarrou in forum General Bike Related
    Last Post: 01-23-16, 09:29 AM
  4. Creative battery charging solution
    By fraschusa in forum General Bike Related
    Last Post: 10-28-11, 08:20 AM
  5. battery charging question
    Last Post: 02-28-09, 04:43 PM
