Results 1 to 13 of 13
Proper Fork Oil Change Technique?
    KB KB's Avatar
    Manchester NH
    I have a Honda Superhawk and it doesn't have the drain screw on the bottom of the fork legs, so in order to drain the fluid I need to remove the entire fork from the triple clamps and dump it upside down.
    The question I have is what is the proper technique to replace the fork oil. Measurement wise that is. I have heard a few conflicting stories.
    1. Measure it out and dump it in
    2. Pour it in and measure from the top of the fork tube with a tape mease until it hit's the oil and both are even.
    Also the springs on the Superhawk are setup for a 180lb rider. I'm 240. Any suggestions on brand for new stiffer springs?
    Thanks in advance.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer legalspeed's Avatar
    Somersworth, NH
    Pour enough in both and then suck some out.
    No really. Peter showed us a mighty vac he uses with a straight tube. The tube is marked with tape, place taped tube at top of fork tube, when the vac makes the end-of-the-drink sucky sound, you have (x) ml of oil in your fork.
    Repeat for other fork, oil is level.
    LRRS\CCS\WERA #486
    Diamond Geezer Kip's Avatar
    Nov 2002
    Cranston ,RI
    Just use rocks. It will work OK for the street.
    Re: Proper Fork Oil Change Technique?
    This is the method I use. I actually use a dowel with a notch where the level should be. It seemed to work, but Kevin will let me know when he gets my forks apart...
    KB KB's Avatar
    Manchester NH
    Originally posted by kmf
    Buy the factory Honda service manual and follow the directions in there.
    The service manual gives you the fork oil height spec.
    Thanks KMF.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Dec 2003
    Massachusetts
    Measuring the height from the top is the only real way in my opinion. The amount in mL or CCs or anything like that is all relative to the work you are doing. Are you completely pulling everything apart, cleaning it, and putting it back together, vs. just a drain a re-fill. You'd have to put in different ammounts. I'm going to be tackling this within the next few days myself. Done it once before.
    StumpyNB
    '11 Kawasaki Ninja 1000
    Senior Member double agent's Avatar
    Sep 2002
    acushnet - yates replica
    I went with progrssive rate springs front and rear. had
    ricerocket 1 sit on it (250lbs) and the new springs held up pretty good . I went with hyperpro f/r springs.
    guy on the vintage Yamaha Rice-rocket1's Avatar
    May 2002
    New Bedford, MA
    Originally posted by double agent
    had ricerocket 1 sit on it (250lbs) and the new springs held up pretty good .
    You try'n to imply some thing???
    j/k
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
    Sep 2002
    just the truth, dont worry Im not far behind you
    aka Johnny Valve Stem need4speed's Avatar
    Aug 2002
    Brookfield,CT
    j/k
    Naw, your not fat, just big boned!
    John
    LRRS\CCS #714
    2004 Duc 620 monster racebike
    89 EX500 racebike - sold
    98 Superhawk 996
    "To repeat what others have said, requires education; to challenge it, requires brains".
    KB KB's Avatar
    Manchester NH
    I am assuming you own a SUPERfrontspringrateblowsHAWK?
    How'd the new spring work out? Did you do any valve work or just springs? Did you do it yourself? Did you have to make a custom spacer for the top of the spring?
    What weight oil did you use?
    Thanks,
    LRRS/CCS EX #13
    GMD COMPUTRACK
    May 2002
    New Bedford, MA
    Originally posted by need4speed
    Naw, your not fat, just have a big bone!
    Why thank you, but you shouldn't be looking.....
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
    Sep 2002
    the f/r springs are made for your bike no spacers are needed. I used 10 weight fork oil and no valve work needed. everthing you need comes with the kit, oil f/r springs and some lube for your rings. I had TONY at the pit stop do the work he had it done in 3 days. www.hyperprousa.com (888)963-1212 nice people Im sure they will help you with any ques you have
  1. Fork oil change
    By DaveZX6r in forum Bike Maintenance
    Last Post: 05-07-12, 10:35 AM
  2. fork spring change
    By darkduc7 in forum Bike Maintenance
    Last Post: 06-29-11, 06:19 PM
  3. My first ever fork seal change
    By CB750F in forum Bike Maintenance
    Last Post: 05-06-09, 05:52 AM
  4. proper turning technique
    By jimaug87 in forum General Bike Related
    Last Post: 07-26-07, 09:02 AM
  5. Proper Group Ride Arrival technique.... 'tard style
    Last Post: 07-13-07, 11:01 AM
