Results 1 to 14 of 14
RC51 fork seal failure
    Member 05RC51's Avatar
    Sep 2012
    tupper lake ny "DAKS"
    My 05 RC started leaking fork oil on the left side tonight on my way to the shop. It pisses me off because it only has 15,000 miles on it and im not a wheelie guy and try to avoid big bumps. So I am going to get some seals and have a good friend of mine do them. Is it common for these to fail at such little miles my last rc had 40,000 miles on it and never had fork seals done
    Re: RC51 fork seal failure
    My gsxr 1000 blew them at 12k. I am a wheelie guy though
    Sep 2012
    I've pulled it up a few times over the crest of a hill type thing but never clutched it up or anything like that
    Sep 2012
    also what brand of seals are good to replace the factory ones?
    Haverhill, MA
    Realize that it is entirely possible that the seal went because it somehow, other than wheelying, got damaged. It is just as, if not more, likely that some road debris attached itself to your fork leg and the next time you hit a bump the seal slid over it and nicked the seal causing the leak.
    When you replace the seal ensure that you check the fork leg for any nicks, scratches, attached road debris you can feel and clean them up otherwise you'll just being doing the seal again not long down the road.
    Joel
    Jan 2009
    Middletown, Ct.
    Joel
    This.
    Not to mention it's an 05. That seal was 8 years old minimum.
    Joel
    This again.
    Relax... it's a fork seal, not a crank bearing.
    OEM seals from the factory. Regardless of mileage, I'd replace the seals and oil in a street only bike every 3 years.
    Track bikes get done at least once a year.
    Sep 2012
    Yea I understand its just a fork seal and a relatively easy fix with the right tools
    Wirelessly posted
    Go with Honda brand oem.
    Wirelessly posted
    +1
    Sep 2012
    Ok I will
    Sep 2012
    seals and a new fork seal driver will be here tomorrow and gonna tackle them friday night
    Two many 2 strokes
    Bradenton FL
    Make sure andwatch some you tube videos on how to do it... You don't want to do it twice... You might need to make a tool to do it...be careful!
  1. Replies: 7
    Last Post: 07-08-11, 11:07 AM
  2. HELP! Fork Seal Replacement
    By kb1 in forum Bike Maintenance
    Last Post: 05-23-11, 12:20 PM
  3. Changing a fork seal/fork oil??
    Last Post: 08-11-10, 07:58 AM
  4. My first ever fork seal change
    By CB750F in forum Bike Maintenance
    Last Post: 05-06-09, 05:52 AM
  5. Left fork seal gone
    By alfred in forum General Bike Related
    Last Post: 08-02-03, 08:34 PM
