Results 1 to 11 of 11
Rear brake question
    Daily Commuter Drewski's Avatar
    Apr 2010
    Haverhill, MA
    Rear brake question
    Having an issue with the wife's '99R6. Changed rear pads and bled the system, all was working fine for a day or two. Now there is no pressure on the rear pedal. If I try and bleed the system again, there is no air coming out the bleeder valve so I'm thinking the master cylinder is working fine. Frozen caliper? I know there isn't much to the rear system that can go wrong. Any help is appreciated as I might be missing something.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Rear brake question
    Frozen caliper won't make there be no pressure on the pedal. Frozen caliper will make it so the pedal is hard to push.
    Air or malfunctioning master is where I would look.
    On some bikes (like my KTM dirt bike), there is a high spot in the brake hose that sometimes gets a bubble after a period of sitting.
    If nothing mechanical is the issue, see if the brake hose has a clear hump in it where air might sit... usually far from either end so when you bleed it is virtually impossible to get it out.
    With my KTM, it's the front brake. I have to physically bend the hose so the master cylinder is the high point, then I lightly touch the brake lever about50 times (less than 1/4 inch movement). Enough to open the hole, but not enough to force fluid down. Eventually, the air bubble moves into the reservoir and my pressure is back.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Lifer ZX-12R's Avatar
    Candia, NH
    Quote Originally Posted by TTD View Post
    From checking out photos of '99 R6's on the internet, there is a big hump in the rear brake hose routing.
    It's worth checking out before you work too hard on other stuff.
    Tony
    Derry NH
    Take the caliper off and hold it above the master and the hump in the line while you bleed. Make sure to put a block of wood or something between the pads so the pistons don't over extend.
    Tony's got it. Air bubble for sure
    Apr 2010
    Haverhill, MA
    Thanks all. I appreciate it.
    Apr 2010
    Haverhill, MA
    Thanks again guys. I finally had time today and after dropping the hump in the brake line lower than the caliper and bleeding the line again, it was perfect in 10 minutes. Thanks for the great advice on what to look for!!
    Cool... glad it helped.
    Tony
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Quote Originally Posted by Eric Baker View Post
    This just worked on a ducati with a higher than everything else hose. Pulled the caliper off and the hold down clamps and bleed it while holding the caliper near the tail light. Finally got some good pedal.
  1. Rear Brake Help
    By throttlejunkie in forum Bike Maintenance
    Last Post: 08-18-12, 10:07 PM
  2. rear brake
    By PPS26 in forum Pit Area
    Last Post: 02-13-10, 09:49 AM
  3. The rear brake
    By -jro- in forum General Bike Related
    Last Post: 06-05-08, 04:58 PM
  4. rear brake pedal/rear light not working
    By seth399 in forum Bike Maintenance
    Last Post: 04-10-08, 09:57 PM
  5. rear brake
    Last Post: 10-01-04, 06:40 PM
