Results 1 to 25 of 34
Need short term fix for crack/hole in exhaust
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Advise needed.
    Cracks develop on the weld of the catalytic on my mid pipe. We attempt to weld ... and well ...
    Question is, can I throw a wrap and be ok until I source a new midpipe or get this to another welder?
    If you were me... what would you do? I'm trying to make the next round next weekend.
    Also... this is an akra system. That can only be sold through ktm dealers. And they won't sell the midpipe as a standalone unit. I have to buy the full system. 900$. Fuck.
    Senior Member MFChop's Avatar
    Apr 2014
    Nashville, TN
    Re: Need short term fix for crack/hole in exhaust
    Is that Ti?
    Titanium?
    Took a welding class at Artisan Asylum and the instructor welded TI bike frames for a living. He went by the name "Skunk." From the work he showed us, it seems like a really skilled welder might be able to repair it.
    Jul 2014
    Central CT
    Don't think it's Ti. A description online says durable high strength steel. Maybe a blend?
    Branford CT
    Rada?
    #277
    Jul 2014
    Central CT
    Rada?
    Ya already touched base with him but won't see him until end of month. Maybe.
    Aug 2009
    Hillsborough County, NH
    JB Weld
    🇯🇵 2001 Honda CBR 929RR R.I.P
    🇯🇵 2009 Honda CRF 250X
    🇯🇵 2013 Kawasaki Ninja ZX636R
    🇦🇹 2016 KTM 1190 Adventure-S
    Aug 2009
    Too much heat, too little patience.
    Jb weld should be good, but I'd wrap it as well.
    The thread title brought me back to my youth when a soup can and two worm clamps would fix and exhaust leak in my $300 cars.
    Jun 2012
    RI
    Yale Muffler Cement. Works wonders... have some on my SV, held together during the wet races.
    642
    Lifer Pittenger5's Avatar
    Austin
    A cut up VP Fuel can and a couple rivets got me through a race weekend once. That would be a tough place to patch it though.
    Zip Tie Alley #505
    Jul 2014
    Central CT
    Yea it's the location that I'm struggling to figure out how to patch.
    I think my solution for this coming weekend is to borrow a mid pipe and send this to Rada to patch up.
    Advice needed.
    Looks like it should be covered under warranty.
    Time is of the essence.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Ifn you want me to weld it don't put any goop of any sort on it...
    Either run it or borrow until I can fix it.
    Jun 2012
    RI
    I would say that warranty went out the window as soon as a welder hit the pipe, unfortunately.
    Sent from my SM-G920T using Tapatalk
    642
    Jul 2014
    Central CT
    I'm covered this weekend. Going to run Lea's mid pipe. (She just upgraded to an akra this year). Will be sending it to you via mail and I'll pick it up at the end of the month in Palmer. No goop.
    Jul 2014
    Central CT
    Also, it was bought from a private seller who bought it in 2015. I'm sure the warranty had expired.
    Quote Originally Posted by Philkinson View Post
    Unfortunately I agree with you.
    Hiram, ME
    Adam will make that better than new.
    I think that went away with the botched attempt to weld it
    Jul 2014
    Central CT
    Product was at least 2 years old. Doubt the warranty was still active. And any welding good or bad would have voided it.
    Lifer Stromper's Avatar
    Eastern Ct
    I would see if silver solder/ brazing stuck if so make a pat ch from steel
    The calculus of hate
    Jul 2014
    Central CT
    I'm through my crisis period here and have sourced an alternate exhaust to run this weekend. Rada will take it and make it pretty. Or at least functional. He can post up how he plans to do it.
    Jan 2017
    Worcester, MA
    I found a few small pinholes in a V&H 4-into-1 that I was prepping for high temp powder. The first attempt to MIG weld them shut resulted in larger holes. I turned down the current and tried again with much better success. I'm sure yours can still be fixed.
    That's it, I'm changing my avatar to the sarcastic green smiley. Jesus people, it's humor. I was drawing a tenuous connection between the fact that my bikes are usually old enough to vote and Isaac's bike is in contrast still smelling of India(ns).
    Jul 2014
    Central CT
  1. short term storage question
    By Nightpoison in forum Bike Maintenance
    Last Post: 02-04-14, 08:12 AM
