Starts fine, idles fine
popping noises when I let off the throttle through the whole rpm range. (loud)
Two flat spot while under hard acceleration 3k rpm and 5.5rpm
Air filter is a little dirty ... But I don't think it will cause this.. Haven't had a chance to pull the plugs yet..
2001 zx11
Sounds like something to do with timing to me. CDI or valve issue? I`ll be watching this thread for obvious reasons. Good luck sorting thos one out.
EBC X rotors up front. One finger stopping with the EBC HH pads. Put a zx6r front fender on for a lot less noise and I think a better look.Thanks Any luck with your motor problem?
start with the basics. clean the carbs, new plugs etc.
I can take a gander at her and try to figure it out for ya if you want. Pm me and we can set it up.
Degsy: "i never had red hair"
