argos?
oem plugs can be hard to find, as I'm sure you figured out. The best may be a scrap harness. Is there one on your old bike?
Tim
LRRS #44
Superbike Services 44
Hey man, if you can source the part, Id be happy to solder it up for you.
Wirelessly posted
If you have a complete old wiring harness, you must have all the plugs you need, right?
IF you have a pair of calipers and time just use digikey or mouser, go to automotive connectors and use search options to cut down the options then view the data sheets till you find a match.
Like I said they say, nothing stops a party barge.
97' Ducati 900SS - Sometimes runs
Jim I have a site you can get the plugs from when I was looking for the injector plug
LRRS EX 66
factoryeffex
Just buy a couple of waterproof wiring connectors and replace the stock ones.
Something like this. http://www.amazon.com/ACCEL-74812-We.../dp/B001HQEUKC
Did this on my Aprilia to replace a burnt out stock connector.
It's for an adapter to plug my tuning cable into the ECU plug. I'm not cutting OEM connectors to solder in a tuning cable adapter.
If I can't find the source for the proper plugs, then I'm just going to rig something up to jam some copper in there while I'm tuning the ECU.
Is this the 8 pin?
http://www.corsa-technic.com/item.ph...category_id=95
Heres the 6 pin page, any of these line up?
http://www.corsa-technic.com/categor...category_id=59
If you get the stuff (or just have me order it and get back to me in September) I can get the cables together for you no problem (what I do for work)
Hahahha Here you go Jimmah one is a repost....
or
http://forums.13x.com/showthread.php?t=305679
Try these.
http://www.easternbeaver.com/Main/El...onnectors.html or
http://www.bmotorsports.com/shop/ind.../cPath/109_219 or
http://www.corsa-technic.com/categor...category_id=54
LRRS EX 66
factoryeffex
if any of these suggestions doesn't pan out try calling Bazzaz and asking them if they have a connector or can tell you where they get theirs
LRRS Am #331
Our terrible suggestions are easily explained by your terrible description of what the hell it is you were trying to do.
I could had this cable YRS ago.....SUKKA
LRRS EX 66
factoryeffex
so basically you posted asking for help, did it yourself and then insulted the guys that offered solutions...
You Sir, epitomize the true spirit of a Nesrian...now![]()
Sam
