Results 1 to 10 of 10
Turn signal issues on my 2004 Katana- HELP!
    OK- Here is my problem..
    I have intermittant turn signal issues. Today while riding the turn signals stopped working. I would have to hold down the toggle in the center position(cancel position) for about 3 seconds then they would work again!!
    after about 20 miles more only the right side signals would work. If I tried to put the left signal on it wouldnt work and the right side wouldnt work either unless I pushed the toggle switch in for 2-3 seconds again
    I got home and the bike sat for 2 hours, I went back out and now the blinkers work just fine- both sides!! I took apart the actual turn signal assembly and it appeared mechanically fine.
    Is this a flasher issue? Maybe it is overheating??
    crasian. Jenni's Avatar
    Feb 2007
    Manchester, CT
    Re: Turn signal issues on my 2004 Katana- HELP!
    refill your blinker fluid.
    no but seriously... that happened to me a couple of times this year... took a couple seconds before it activated. i forgot about it until it happened again. i'd be curious for an explanation as well.
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Clean your turn signal switch and put some electric grease on it.
    It seems too intermittant to be a contact issue Noxin...... I think it is electrical not mechanical like a bad connection...........
    Quote Originally Posted by Lxpony View Post
    Quote Originally Posted by noxin View Post
    There can be "bad connections" in the switch as well....they're called "contacts". Clean them and report back...
    Apr 2008
    Boston, MA
    I found out that my connections were just taped together before I bought it so I soldered mine a while back.
    That said, the Matco Butane soldering iron is a piece of shit and I wish I didn't drop over $100 on it. The Snap-On/Bluepoint my old boss had worked great all the time, I'll probably snag one for myself for Christmas.
    Apr 2008
    Boston, MA
    the $20 radio shack butane soldering iron works wonderfully
    Lifer ZX-12R's Avatar
    Candia, NH
    Bad contact is an electrical issue.
    A flasher relay has a bimetallic strip that heats up when electrical current is passed through it. The bimetallic properties of the strip cause it to bend in one direction when it heats up. The bending breaks the electrical connection to your directionals which turn off and since there is no current flowing through the bimetallic strip in the flasher, it eventually cools off, clicks back over, and turns your directional back on which repeats the process. If you have a bad connection in the switch, it's possible that not enough current is flowing through the flasher to make it flash.
    The cheapest and easiest thing to do is to clean the contacts in your directional switch. If that does not work, replace the flasher.
    youre so smart
    Candia, NH
    youre so smart
    Don't confuse long posts with being smart!
  1. 23w turn signal bulb
    By tonup in forum Bike Maintenance
    Last Post: 04-11-11, 07:20 PM
  2. Turn signal requirements in MA
    Last Post: 10-13-10, 09:50 AM
  3. Turn signal woes
    By Zolden in forum Bike Maintenance
    Last Post: 06-05-08, 09:18 AM
  4. VFR turn signal connectors?
    By bemused in forum General Bike Related
    Last Post: 04-10-03, 10:21 AM
