Results 1 to 25 of 42
Spring wake up fail
    Spring wake up fail
    So, I fired up my new to me triumph 675 after a long winter's nap. She fired right up, but idled a little rough. Then the CEL came on. If I try to ride it, it rev and go, but as soon as I let off the gas it dies.
    I suspect water in the gas, but would that throw a cel? Also, the tank is the biggest pain in my ass ever. Is there any reasonable way to get some fuel out of this thing?
    Re: Spring wake up fail
    If you think it's water, is it worth a shot to try some drygas in it?
    If I remember reading some of your posts, didn't you do a fair amount of work to it recently? Is it possible you may have bumped a connection, or forgot to plug something back in?
    If it makes you feel any better, my Aprilia ran flawlessly today..I was pleasantly surprised
    Lifer golden chicken's Avatar
    Attleboro, MA
    I'd pull the fuel line and jump out the pump. Let the pump do the work.
    I have a cheap squeeze bulb primed syphon for draining tanks. $4 at Wally World.
    Bellingham MA
    Apr 2012
    Mine did the same thing after the winter with the CEL. Try to clear the code and see if that works
    Try this-
    Turn ignition on, Twist full throttle and turn kill switch it ON/OFF/ON/OFF/ON/OFF Just DO NOT hit the starter button anywhere in there.
    That should clear the code
    Did it not run right? Or just throw the CEL?
    Nov 2007
    This may sound silly but check for mice nests and shit in the airbox. That happened to a bike I had, it was running shitty but I could keep it running by maintaining throttle... turns out there was a mouse nest in the airbox.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Apr 2012
    It had the cel and idled really poorly. I read somewhere that a CEL causes the daytona to work in "limp home mode".
    My buddy cleared the cel for me, it didn't come back and it runs well now
    OK, I'm thinking mouse nest as well. Thing thing is it's a sealed airbox with a cage over the intake. I still suspect the mice theory though becuase there was a towel on the bike that had been shredded up a little. Never found where that went...
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    I also had a mouse nest in the air box of my MV Brutale...how the hell did they get in there???
    Raymond NH
    Pump gas already is 10% dry gas. Adding more won't help.
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    This is what I found when I popped open the airbox on the SV 3 weeks ago.
    Someone got up thru the snorkel.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Er, where'd you come up with that number? If you're referring to the Ethanol content, it's the exact polar opposite in effect to dry gas. Ethanol sucks the water in and then helps it separate out so you've got pockets of H20 in your fuel, if not a nice layer of it on the bottom of your metal tank, rusting away.
    Dry gas is Iso Propyl Alcohol, it binds with the water, keeping it in solution so it can pass through your fuel system without impact, or freeze, etc.
    TLDR - Ethanolated fuels need drygas MORE than ethanol free fuel.
    CEL probably from a cyclinder misfire. No big deal... get that old gas out of there and see if it clears itself.
    Nov 2007
    I should say that the bogging and stuff with the mice nest getting caught in the airbox/filter also did cause the bike I mentioned to throw a CEL.
    So your description sounds EXACTLY like what happened to me. I vote mouse nest.
    LRRS/CCS #103
    I93/495
    Store it with mothballs stuffed near all the openings. Keeps the critters from going in there.
    Same thing with cars. Bag in the car, in the glove box, under the hood etc. Makes life much easier when they don't chew through wiring etc. ..
    if you're looking to easily get the gas out of your tank, this is your best friend: http://www.amazon.com/Safety-Siphon-...pr_product_top
    Yeah, Thanks Jim, I'm gonna grab one of those, but I'll check for rodents first!
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    For the guys who have gotten rodents in the airbox, did this happen with storing the bike inside a garage? Reason I ask is I've always had my bikes stored in a garage when not in use (even during riding season) and I've never had rodents in my airbox. I usually plug up the exhaust ports with WD-40 soaked rags for peace of mind sake in the winter. Just curious to see if it's more common with storing the bike outside vs inside an attached garage.
    if you're anywhere near Boston, you're welcome to borrow mine.
    This is your $9 cheaper best friend for the same thing.
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Just got one a couple weeks ago. Pretty slick little device.
    ya i got mine from the manufacturer directly and it was like $8. i just googled "jerk it gas siphon" , no joke.
    Lifer Falko's Avatar
    MoonTown
    I've never had it happen to the bike in the garage, but it happens to my mower in the shed all the time. My friend who stores his bike for the winter in his shed, mouse nest.
  1. Replies: 13
    Last Post: 06-27-16, 09:28 AM
  2. epic fail - Motorcycle Wheelie Crash Fail
    By FirstDuc-1098 in forum General Bike Related
    Last Post: 06-14-11, 03:58 PM
  3. Rossi replica fail..... no really. FAIL
    Last Post: 09-02-10, 10:07 PM
  4. That'll wake ya up...
    Last Post: 10-05-06, 08:52 PM
