Results 1 to 18 of 18
sprocket problem!!!
    Senior Member double agent's Avatar
    Sep 2002
    acushnet - yates replica
    sprocket problem!!!
    I changed my f/r sprockets and now my bike has a hard time shifting. I thought I might have put the front on backwards ,so I switched it and the same thing . also when the bike is in neutral the rear spins up,feels like the clutch is constantly grabing. I am out of ideas and patience. anyone?
    If money is the root of all evil,
    why do churches beg for it?
    Lifer ZX-12R's Avatar
    Candia, NH
    sprocket problem!!!
    New sprockets shouldn't have anything to do with the symptoms you have.
    Sounds like your clutch adjustment is out of kilter. You will probably have to adjust your cable so the clutch completely disengages when the handle is pulled in. As you have discovered, it is damn near impossible to shift a bike when the transmission is loaded.
    Play with the cable adjustment first and then get back to us.
    Sep 2002
    sprocket problem!!!
    the bike was fine before I touched the sprocket. I never even went near any clutch adjustments.
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    sprocket problem!!!
    how tight is your chain?
    Brent LRRS #772
    2006 KTM 560 SMR
    Lifer lopycam's Avatar
    Aug 2003
    Cow Hampster
    sprocket problem!!!
    I bet it is too tight.
    Sep 2002
    sprocket problem!!!
    the chain was not even tight yet . I brought it to THE PIT STOP,and tony who knows my bike had no clue,yet.
    Sep 2002
    sprocket problem!!!
    bent shift rod!!!!! from having the rear off the ground and in gear and put impact gun to countersaft nut.
    expensive mistake.
    Mar 2002
    Amherst, NH
    sprocket problem!!!
    D'OH!
    Brent LRRS #772
    2006 KTM 560 SMR
    sprocket problem!!!
    ooohhhh, shitty. How much is that gonna cost ya?
    Sep 2002
    sprocket problem!!!
    aprox- $600 labor. dont know how many of the 3 shifters are bent but approx $45-50 each. while I'm spending the money and have the motor out Im trying to think of mods to do.hehehe
    KB KB's Avatar
    Manchester NH
    sprocket problem!!!
    First off that sucks
    Secondly WTF was you thinkin with the impact? Damn that sucks dood.
    You need to pull the engine to fix that?
    Good luck brotha.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Sep 2002
    sprocket problem!!!
    the bearing behind the case and the (washer) that was behind it was locked on the shaft also 3rd/4thgear need replacing.
    so-- lesson learned. don't take off front sprocket with rear tire in the air and in gear.
    May 2005
    Bernardston, MA
    sprocket problem!!!
    Why not? Thats how I did it, except with a breaker bar. Tell your transmission to not be such a pussy.
    NESR's Rocket girl Double"D"'s Avatar
    Jul 2002
    New Bedford, MA
    sprocket problem!!!
    That sucks Chris, big money for a little mistake.
    04 ZX-10R
    02 CBR600 F4i (track bike)
    68 Oldsmobile 442
    05 Tahoe
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    sprocket problem!!!
    So I'm assuming the correct way to do the front spocket is with both wheels on the ground and in neutral?
    I usually don't mess with the front spocket. But it would be nice to know.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    sprocket problem!!!
    you are lucky too..that is absolutely the wrong way to do it....have someone step on the rear break or sit a 2x4 in between the swingarm and a spoke....
    very $$ mistake to make...sorry to hear
    Sep 2002
    sprocket problem!!!
    yeah, I was one step ahead of myself. good idea red about the 2x4 I will use that next time.( by the way spell check)
    break or sit ?
    KB KB's Avatar
    Manchester NH
    sprocket problem!!!
    I use the 2x4 method myself.
    Works mint guy!!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Wanted - Parts & Tools | Gen 1 SV650 45T 520 Sprocket
    By Duffy21690 in forum Wanted
    Last Post: 05-11-16, 10:04 AM
  2. TAKE OFF's FS - Plus a Chain/sprocket set for an R6
    By fastfreddy333 in forum For Sale
    Last Post: 09-11-12, 12:15 PM
  3. CS sprocket??
    By duganc1717 in forum Bike Maintenance
    Last Post: 10-02-09, 12:14 AM
  4. casesaver on crf with 15t sprocket
    By seth399 in forum Pit Area
    Last Post: 01-15-09, 09:00 PM
  5. Sprocket!
    By Stoneman in forum Welcome and Intro
    Last Post: 03-18-02, 12:31 PM
