Results 1 to 7 of 7
Steering Damper loose?
    Member Drewgrace's Avatar
    Everett, MA
    I have an 08 GSXR1000. I noticed that the Stock Steering Damper is a little loose. The Red Arrow is the screw/nut I tried to tighten, but it didn't move. The Yellow Arrow is the assembly that is a little loose. I went to the dealer at Parkway, and the guys there showed me other Gixxers that had the same play on them. Is this normal?
    Steering Damper loose?-steering-damper-001-arrow-jpg
    http://youtu.be/BL3OEcImqGk
    Wirelessly posted
    Normal. It's called a heim joint.
    Re: Steering Damper loose?
    What blue arrow? You color blind?
    What's loose is probably the ball joint, which is pretty much what you're pointing to. The ball joint is there to allow the forks to turn. It's not supposed to be rigid.
    EDIT: Heim joint... yeah, that. Thanks Degs.
    Everett, MA
    Oh crap your right its the YELLOW Arrow Thnx Folks for the quick replies.
    ...inside the van. loudog's Avatar
    Central, MA
    s
    There is semi-spherical bushing in there...when you're cranking down on that bolt, you're putting pressure on the bushing not tightening the joint up (which is supposed to move around freely).
    Retired LRRS/CCS EX #212 | Woodcraft | Armour Bodies | Dainese USA |
    Everett, MA
    Oh I didn't crank the bolt. I just tried to tighten it a little, and had no give so I left it alone. I'm too Chicken to go Beefy Mits Crazy tighting bolts on Baby.
    Central, MA
    Quote Originally Posted by Drewgrace View Post
    That coward emoticon is hilarious.
    BTW: I didn't mean that to sound accusatory...I probably should've written 'tightening up' instead of 'cranking down'. Blasted tone-deaf interwebz.
  1. Steering Damper
    By Larry in forum Wanted
    Last Post: 08-23-12, 09:12 PM
  2. WTB 98-01 R1 steering damper
    By mack0092 in forum Wanted
    Last Post: 02-11-11, 01:40 PM
  3. WTB Steering Damper 03 r6
    By Jenni in forum Wanted
    Last Post: 01-22-10, 09:25 AM
  4. Steering damper $?
    By oVTo in forum General Bike Related
    Last Post: 06-12-09, 02:09 PM
  5. steering damper
    By Qfactor in forum General Bike Related
    Last Post: 09-27-05, 01:55 PM
