Results 1 to 25 of 25
Striped fucking torx bolt heads
    Foxboro, MA
    What the fuck!??! I hate these things - its like 1 in 5 just spin round round
    fucking using them on the rotors, wtf yamaha!!
    somebody get these 3 bolts out of my wheel
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: Striped fucking torx bolt heads
    They must have lock tite on them.
    Foxboro, MA
    oh yah - and its red
    2006 Yamaha R6
    heat first, then torque. Now, dremel...
    Posting Freak idratherberidin's Avatar
    Apr 2008
    Danvers, Ma
    the damn striped ones always seem to be stripped
    Foxboro, MA
    dremel you say... go on...?
    2006 Yamaha R6
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Quote Originally Posted by Crash Dummy Denno View Post
    dremel a + in the bolt and use a phillips impact driver? +1 on the heat
    Quote Originally Posted by bigred875 View Post
    Yes to all. I usually just dremel a - to fit my biggest impact flat head and use that and heat. A 4 lb hammer on the impact driver helps. No carpenter's hammer.
    Lifer Evil_Weasel's Avatar
    Over the Highside
    TIG weld a small piece of steel to it like a handle...twist counter clockwise...gloat over victory
    As usual, your post displays a complete lacking in any fucking idea what you're talking about.
    Hey, at least you're consistent.
    Lifer DuncanMoto's Avatar
    I have an impact driver and a propane torch you can borrow.
    Or just bring it by here and I'll show you how it's done.
    Harlingen, Texas
    I hate Torx as well! I usually end up replacing them with allen head screws if possible.
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    Have Scott suck on each one with his big pink lips and they'll back right out...
    Q
    ps: I can help worst case scenario and I might even have the correct bolts to replace all those torx heads.
    Get some plaid ones, they hold up better than the striped ones usually.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    I have had sucess by puting a good tool in the screw
    then clamping the head with my biggest visegrip set on Gorilla
    this distorts the head so it grips the tool
    Glen Beck is John the Baptist
    Dec 2003
    Ma
    Pour some chocolate on them and have Hardcore eat his way through.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Go to sears and buy this for $18
    Then, punch a divet in the center of each bolt, drill a hole using the drill bit that correlates with the size extractor you use, then heat the crap out of the wheel... move the torch around a bit (dont leave it on aluminum wheel in one place long), but don't allow flame to hit rotor...
    Use extractor (I'd recommend with a tap handle).
    P.S. It's torx? I thought they were allen - replace with allen (socket head if you have the clearance) and blue loctite. If you use socket head, in the event you strip them out again (hey - I know your mechanical abilities, and it could happen) you can avoid the drilling and extracting with a bolt removing kit (about 5x more reliable than extractor in above photo):
    Lake Champlain, VT
    If you want to try easyouts I got a set you can have for free. 508 713 5663
    Two many 2 strokes
    Bradenton FL
    I weld another bolt to the head then you can use a socket to romve it
    Lake Champlain, VT
    Quote Originally Posted by DynoTune View Post
    denno... weld?
    how in fuck do you strip a torx, they can withstand more torque than any other type of fastener head
    Wirelessly posted (BlackBerry8330/4.5.0.160 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Usually by using one size too small torx socket
    The torx bolts used by Yamaha for the brake rotors have very shallow torx slots in them. Trust me, they strip VERY easy..add a Denno in the mix, and well you see the results
    if that's the case, the hand imact with the proper bit and a 3-4 lb sledge
    should be how you attack it in the first place
    Apr 2008
    Boston, MA
    It's a good thing it's striped and not spotted!
    I would just drill the hole bigger then hammer a bigger torque into it. That's how I got my hex rotor bolts out after they got stripped
  1. E15 torx socket
    By backinthesaddle in forum Bike Maintenance
    Last Post: 12-02-20, 12:36 AM
  2. School me on Torx/Star bit sizes?
    By gregp in forum Bike Maintenance
    Last Post: 04-30-13, 09:02 AM
  3. SP2 Front upper cowl "V" striped
    By Half Squid in forum Wanted
    Last Post: 01-24-10, 04:50 PM
  4. Just A Heads Up...
    By Stoneman in forum Track Day Forums
    Last Post: 07-12-05, 09:30 PM
