They must have lock tite on them.
the damn striped ones always seem to be stripped
I have an impact driver and a propane torch you can borrow.
Or just bring it by here and I'll show you how it's done.
I hate Torx as well! I usually end up replacing them with allen head screws if possible.
Have Scott suck on each one with his big pink lips and they'll back right out...
Q
ps: I can help worst case scenario and I might even have the correct bolts to replace all those torx heads.
Get some plaid ones, they hold up better than the striped ones usually.
I have had sucess by puting a good tool in the screw
then clamping the head with my biggest visegrip set on Gorilla
this distorts the head so it grips the tool
Glen Beck is John the Baptist
Pour some chocolate on them and have Hardcore eat his way through.
Go to sears and buy this for $18
Then, punch a divet in the center of each bolt, drill a hole using the drill bit that correlates with the size extractor you use, then heat the crap out of the wheel... move the torch around a bit (dont leave it on aluminum wheel in one place long), but don't allow flame to hit rotor...
Use extractor (I'd recommend with a tap handle).
P.S. It's torx? I thought they were allen - replace with allen (socket head if you have the clearance) and blue loctite. If you use socket head, in the event you strip them out again (hey - I know your mechanical abilities, and it could happen) you can avoid the drilling and extracting with a bolt removing kit (about 5x more reliable than extractor in above photo):
If you want to try easyouts I got a set you can have for free. 508 713 5663
I weld another bolt to the head then you can use a socket to romve it![]()
how in fuck do you strip a torx, they can withstand more torque than any other type of fastener head
Wirelessly posted (BlackBerry8330/4.5.0.160 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
Usually by using one size too small torx socket
It's a good thing it's striped and not spotted!
I would just drill the hole bigger then hammer a bigger torque into it. That's how I got my hex rotor bolts out after they got stripped
