Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
I need suggestions - poorly running GS500F
    Re: I need suggestions - poorly running GS500F
    SUCCESS STORY!!!
    So was it the ground or the needle valve seat?
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Sweet! Nothing beats that feeling when it finally works Your son is very lucky
    05GSXR75005SV65090DR350
    100 X slower than Gerard scootertrash's Avatar
    Alton Bay, NH
    SUCCESS STORY!!!
    I am not quite sure.
    I put the carbs back on after the 4th try and it still didn't run great. I was ready to push the thing off a cliff. So I went back and triple checked the ignition again. I was getting spark on the bad side. But I was wondering if maybe the CDI box was messed up like Kurlon mentioned. The only modification to the wiring harness was where the guy before me changed front directionals to LED ones. Then I saw a broken ground wire, but it was not in the group of wires for the ignition components, it appeared to be in a group going to the front dash, maybe for one of the lights in the tach or speedo? I would have to pull apart a lot of stuff to trace it all out. I fixed it. Logically I don't think it was that wire. If it was anything electrical, I think it would be more likely the fact I was working on the wiring harness, disconnecting and reconnecting things, and maybe I somehow fixed a loose connection that was effecting the timing on the bad cylinder. It doesn't seem likely given the simple electrical design of the system, but who knows.
    So my vote is the carbs were the main problem.
    Concord NH
    Awesome man. glad to hear it's all good now. oring could have had some affect, or you just finally dislodged something that was plugged up. either way, I'm sure you guys are excited.
    Mar 2016
    Falmouth, ME
    Quote Originally Posted by scootertrash View Post
    I haven't messed with the electrical on the GS much but a bad ground can cause all sorts of crazy issues, and get worse under higher load, which sort of fits the same symptoms as carb issues. Either way you have some very shiny carbs now!
    Alton Bay, NH
    Quote Originally Posted by Tekime View Post
    I'm the lucky one. My son is the best. Great kid and a hard worker. He is working two jobs to earn money, plus volunteering at a museum.
    Lifer Stromper's Avatar
    Eastern Ct
    Now teach him
    Practice Panic stops
    Target fixation , go where you look
    Lean lean lean the lean some more
    Panic slow to 10 then swerve
    You pay for attgat
    My boys are NOT being motorcycle supported they will have to be 21 and pay for themselves
    They have mini dirt bikes
    Pani
    The calculus of hate
  1. Running a little rough - suggestions?
    By scootertrash in forum Bike Maintenance
    Last Post: 03-21-16, 07:46 AM
  2. WTB: GS500F
    By TTA89 in forum Wanted
    Last Post: 07-16-11, 10:38 PM
  3. 2006 Suzuki GS500F
    By VT-GSD in forum For Sale
    Last Post: 11-28-10, 10:49 PM
  4. Looking for an 06 GS500F black.
    By Jank in forum For Sale
    Last Post: 08-31-08, 06:43 PM
