Results 1 to 9 of 9
SV popping at low rpms
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    2000 SV650.
    Leo Vince slip on.
    Stock Jetting.
    Sounds like I am making popcorn if I let off the throttle or putt at low rpms.
    I just cleaned the carbs and replaced the plugs hoping it would help.
    Jetting?
    I would rather drop this off somehwere and have it tuned as I have way too many house projects to spend my time on. Suggestions on shops?
    Thanks!!
    Does it do it when it only cold? Or does it do it warm as well?
    What happens if you turn up the idle screw?
    May 2003
    Charlton, MA
    Cold or warm. Idle screw makes no difference as far as I can tell
    Might be lean because of the jetting.
    My 99 has a full M4 system with larger jets and it pops a lot with lower idle when it's cold. But it goes away once it has warmed up.
    Re: SV popping at low rpms
    Quote Originally Posted by McBiggity View Post
    sync the carbs, don't do half the recomended work and think its gonna run right
    also check for vacuum & exaust leaks
    May 2003
    Charlton, MA
    I did the work that I could with the tools at my disposal.
    Any suggestions on place/person to synch the carbs?
    PM TLRMan. He'll get you straightened out. He's out in Beverly, MA though, so it's a hike out there.
    Worcester, MA
    Hey, I know a guy with a sync tool.
    LRRS EX #165 (formerly)
    May 2003
    Charlton, MA
    Should have told me yesterday! Sent you a text
  1. need help! engine noise, skyrocketing RPMs
    By martyk in forum General Bike Related
    Last Post: 05-28-12, 08:48 PM
  2. Mixture Problems and RPMs out of control
    By demo19 in forum Bike Maintenance
    Last Post: 09-20-08, 01:15 PM
  3. Engine clicking/popping
    By JunoAF in forum Bike Maintenance
    Last Post: 08-06-08, 07:03 AM
  4. Popping noise out exhaust @ 6500rpm on ninja 250?
    By spicy in forum Bike Maintenance
    Last Post: 06-19-07, 09:11 PM
  5. Popping noises coming down from high RPMS?
    By joberly in forum Bike Maintenance
    Last Post: 08-06-04, 09:34 PM
