Results 1 to 25 of 33
sv650 weird noises
    FUCK OFF Hardcore's Avatar
    Jul 2005
    norwood ma
    sv650 weird noises
    anyone got any ideas what might be wrong with my sv650?
    I just changed the oil + filter + took the bike to VIR.
    it ran very good for 2 days straight but for my last session of the 2nd day, it got really fast for a few laps + then on the straight away started making all kinds of loud knocks,pings,+ clanking noises, so I shut er down + coasted to a stop off track.
    I can start it now, but it sounds like a cement mixer.
    anybody have any ideas as to what might be wrong with it--I can't afford to take it to the shop for diag!!
    will changing the oil again with a heavier grade maybe help?
    Sep 2007
    Middlebury VT
    Re: sv650 weird noises
    Check oil level.
    Change oil.
    Examine filter for "bits".
    Fuel quality?
    Worcester, MA
    yeah definatly check the oil for any metal bits.
    LRRS EX #165 (formerly)
    Usually when they run Extra fast its about to go boing.....
    Raymond NH
    My theory:
    "Really fast" means it probably leaned out a bit at WOT due to fuel delivery issues. The pinging, and knocking were due to detonation from too much heat due to leaning out. The clanking and subsequent cement mixer noise is due to internal damage from detonation.
    Hope I'm wrong.
    They usually have crank probs... something about not enough endfloat and it not being set with shims, but rather just the cases. You're gonna have to tear it down. No amount of oil will repair that kinda damage...
    Foxboro, MA
    that sucks chad... thankfully it happened on the last session though
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    how loud?
    it's very normal for the SV to make noise that may come & go (cam chains get kinda slap happy)
    Normal Sounds
    Quote Originally Posted by hardcore View Post
    Can I have your throttle tube?
    Lifer Wishbone's Avatar
    Jul 2006
    It was telling you your to fat and it hurts : Your a wrench by trade! You should know what the problem is
    Winchester, MA
    My guess would be cam chain jumped a tooth or three and advanced the timing?
    Seems like the tensioners on bikes are a common weak point.
    Lifer reiobard's Avatar
    Jul 2005
    Bennington, NH
    lets hope that this is the issue...
    Jun 2005
    Hmmm... If that were the case would you expect an almost immediate boom as mr valves meet mr piston? Dunno... It definitely could be the case... That would definitely explain the cement mixer sound. Gonna need to tear it down for sure. Should be relatively easy to verify timing with marks on the cam sprockets and the cylinder at TDC.
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    only on second gen (03+) as far as I know
    Jul 2005
    norwood ma
    this post was a test
    anyone that answered or thought ANYTHING other than--that motor is toast--FAILED !!!!
    thank you all for your answers but be assured--ANYTIME--a motor suddenly speeds up + then starts pinging,clanging,knocking,+ rapping, your bearings have spun + are about to seize or break!
    Feb 2004
    Bellingham, MA
    Amazing the number of keyboard heros huh???? Try changing the oil, might be a cam chain tensioner.....how about the valve clearance.
    Hey here's a thought, how about you can't diagnose a problem on a forum. Good one fat fuck, good one.
    "The Internet, 100 million losers can't be wrong!" (one of my favorite t-shirts)
    Just Registered Doc's Avatar
    Jericho, VT
    Chad just time the fucking thing and it will be good to go! :
    OH... BTW... DID YOU ADVANCE TO AMATUER?!!!
    Jul 2006
    HA! I win then!
    To fat+ringing it out for to long=by by motor
    Nov 2007
    Raymond, NH
    this post was a test....
    ...to see if your computer was working again?
    so how is the SV really running?
    Lifer union's Avatar
    Blackstone, MA
    NExt time just get a bottle of crank straightener. Shit works wonders
    James
    Winchester, MA
    Why would a spun bearing cause the motor to speed up?
    Lifer BostonSVkid's Avatar
    Dec 2005
    I might have an engine for you soon so I will let you know haha.
    2006 Ducati Monster S2R800
    +1
    I've spun bearings and never had a motor speed up. It just loses power and runs rough in my experience.
    Jun 2005
    +2
  1. Ducati Starting issues. Bad Noises. HELP?
    By Doc in forum Bike Maintenance
    Last Post: 05-10-11, 03:42 PM
  2. Popping noises coming down from high RPMS?
    By joberly in forum Bike Maintenance
    Last Post: 08-06-04, 09:34 PM
  3. Weird...
    Last Post: 07-01-02, 12:28 PM
