Results 1 to 6 of 6
need carb help ASAP!
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    I have someone coming to look @ my GSXR 1100 tomorrow, I started it a few minutes ago and the Tee-adapter thingy between cylinders 3 & 4 is pissing gas !
    Anyone have an idea why gas would be leaking from the tee?
    Jan 2007
    Rochester MA
    Re: need carb help ASAP!
    Not an expert, but it sounds like your floats are stuck. Tap the sides of the float bowls with a piece of would or something that wont damage them, that should break them loose...
    Lifer Evil_Weasel's Avatar
    Over the Highside
    Quote Originally Posted by b0xmonkey View Post
    that is assuming the T thingy you mention is the carb over flow.
    don't just beat the carbs with a stick, though it will work in a pinch. what they really need is a good cleaning and maybe a rebuild kit with new needles and seats. don't forget to check and adjust float height before reassembly.
    As usual, your post displays a complete lacking in any fucking idea what you're talking about.
    Hey, at least you're consistent.
    Dec 2008
    Framingham
    Yup, talked to TLRman and tried tapping the bowls and removed the number 4 cylinder bowl. Float on the number 4 cylinder seemed fine, couldn't get the number 3 cylinder bowl off w/the carbs on the bike.
    Guess I'll cancel the sale of the bike
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Is it cold may just be a spot of ice
    Warm up and run
    Glen Beck is John the Baptist
    Over the Highside
    Quote Originally Posted by richw View Post
    Warm up and run
    yes if you warm it up with that gas leak deffinatly run
  1. Replies: 21
    Last Post: 09-27-10, 05:13 AM
  2. WTB: Leathers ASAP
    By 6 Fingered Man in forum Wanted
    Last Post: 04-08-10, 09:22 PM
  3. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
