Results 1 to 17 of 17
Need a teflon job done
    Senior Member nixoid's Avatar
    Sep 2005
    Watertown, CT
    I'm re-doing the top end on a motor and want to decrease friction in a few key areas and was looking for a shop that could induce teflon into my cam, wrist pins, and rings.
    Anyone have a line on this type of service? Post up if you do.
    Kevin aka nixoid
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Need a teflon job done
    Not sure that makes sense TFE very weak and soft.
    Very thin industrial hard chrome plating then mirror polish would be nice. Chrome directly on steel not copper-nickel-chrome like bumpers. Thick chrome can peel off and do bad things.
    Glen Beck is John the Baptist
    Lifer union's Avatar
    Blackstone, MA
    Racing this coming year?
    James
    Dec 2005
    Near The Dragon
    the most effective friction reduction treatment out there is molybdenum disulphide.
    the reason is that moly is not a seperate entity like oils and teflons, it bonds itself to the metal at a molecular level, and is considered an 'extreme pressure' lubricant
    some pistons come with moly skirts, and most engine assembly lubes are high in moly content
    Get out while you can
    Find your own path
    Lifer Currently's Avatar
    Ooltewah, TN
    Do a google search on ... Slick50 AND Lawsuit
    Teflon has its place, not on hot metal that has pressure wear.
    If loud pipes save lives, imagine what learning to ride would do.
    Hold the throttle open longer and brake later.
    Sep 2005
    Watertown, CT
    Quote Originally Posted by richw View Post
    TFE is used in racing applications. It is a proven method of friction reduction. I just don't have the name of any shops that do it. I'm trying to stay away from plating to keep within tolerances. trying to do a "stock build" with a little flair....
    Oct 2007
    Peabody Assachusetts
    Did you look into Calico Coatings?
    Sep 2005
    Watertown, CT
    Quote Originally Posted by brendanp View Post
    They do Teflon work but there are no descriptions I can decipher from their site I will contact them thanks for the heads up.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    i would rather waste my money on slicks
    Sep 2005
    Watertown, CT
    I'm doing something completely different - 650 mile endurance race on open streets - no slicks, extra seat cushion maybe....
    Aug 2004
    Baltic,CT
    I am sure it would help with 1 race especially to permit full power without break in
    I just think it disappears in minutes
    I think jet hot does engine coatings. It's usually for heat control, but it does have some durability/friction benefit as well.
    Foxboro, MA
    its a fuckin EX500 kevin - you got to be shitting me!!!
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Sep 2005
    Watertown, CT
    Quote Originally Posted by Crash Dummy Denno View Post
    It's far worse than that. it's for my little bike. [insert laughter here]
    Did you ever get your gear denno?
    Foxboro, MA
    Quote Originally Posted by nixoid View Post
    yesterday I finally got the jacket - haha - perfect timing
    2006 Yamaha R6
    Sep 2005
    Watertown, CT
    How about the pants.... did they get dome and did they fit her?
