I was turned on to a way of mounting my tires onto the rims without tools, I was skeptical a but gave it a try,,,, WOW ,,,mounted my front tubeless 150/80/17 with only my hands and a little bit of bead lube. This would also work extremely well in preventing pinched tubes. Same technique could be used to remove tire form rim after bead is broken. Use zip ties around the tire (I used nine) to close the beads down until they meet each other. Now you can mount the tire while on the first side started being able to keep both beads in the deepest part of the rim giving lots of room to slide both beads completely on using no tools just bare hands. Keeping tools away from the rims and beads/tube is a win win situation.
sounds similar to this
http://www.advrider.com/forums/showthread.php?t=299597
For a small fee I can give you advice on any subject.
For 10 bucks I will tell you how I use a 2x4 and a shed to break the bead without ruining the rim.
man i gotta try this.
"fuckit!"
hey, new demount method. For 10 more dollars I will show you how to dismount without a dismount...
LRRS 878 Clapped out Gixxah
And then I found $5.
- HP
This thread is full of win, I've made $15.25 so far!
I can vouch for the shed technique!
Its when he started to offer me candy and come inside I got nervous![]()
Kham , I think thats an offer you should not refuse!I didn't want some one coming by for a totally free mount
Come to my house and I will instruct you how it is done. Ive changed ALOT of tires using simple methods. Never scratched or ruined anything YET!
I only charge 1 million dollars...Bwaaahahahahahahahaa
For you 0.01 dollar.![]()
