Results 1 to 25 of 33
Custom map
    Lifer gixxer72's Avatar
    The desert
    Custom map
    Need a custom map for my 07 gsxr1k, recommendations on a good shop in ME, NH or eastern MA? Thanks
    Southern, NH
    Re: Custom map
    PM TLRMAN on here
    he'll take care of ya.
    he's in Peabody
    Re: Custom map
    or RJ's Motorcycles
    Re: Custom map
    Not that TLR man is not worthy but I would and Did go thru Jamie @ FuelMoto....he has any map that you could need. I have a Jap Yosh shorty and he was the only on with a Map that I could find...and it was a Killer power curve at 156.4 Hp with just bolt on stuff...mine was 265 shipped and he has an eBay and Paypal acct.
    Here...... Fuel Moto USA
    Meriden, Ct
    Re: Custom map
    Bazzaz...
    Re: Custom map
    If you're near southern Maine, Moto Milano in Windham has a Dynojet 250i with eddy current brake and is fully setup and trained to build custom maps for PowerCommander equipped bikes. They also use the heaviest drum Dynojet offers, so they can get more repeatable results, and more consistent data to build the map off of than the other Dynojets installed in the area.
    Northshore/Beverly, MA
    Re: Custom map
    For the most part, put it on the dyno. The problem is that your bike is sitting there spinning a loaded drum. Now, you got your nifty map that works good on the dyno, and shows all that booming HP you got. Now drive your bike on the street, and I'll bet you will notice some spots that annoy you. This is where I come in. The idea is to tune for a wide spectrum of torque, and HP, that works well on the street. Who cares what it does on the dyno at max HP,and RPMs, is this is where you ride all the time? Your bike was designed to roll on pavement, and mingle in traffic.
    Most bikes have "ram air", and this can't be compensated for. Sure, maybe close, but there are issues with air intake temps, and general temperature of the engine as well. I have always noticed differences from "Driving the Drum", and actually riding the bike in a "Real World" environment.
    I guess I do have a reputation for finding things that can be made better, but
    I'm just here to lend a hand, no claims to fame, or getting 150 HP out of your Gixxer 600. Just sorting out the bugs, and giving you good all around performance, and drivability.
    Re: Custom map
    PM TLRMAN on here
    he's in Peabody
    Hey Bill...I'm in Beverly....
    Southern, NH
    Re: Custom map
    oops
    Re: Custom map
    Peabody, Beverly, aren't they all the same out on the North Shore?
    Re: Custom map
    If that's the case, someone skimped out mapping the lower throttle settings... it's tedious and time consuming as you typically can't use roll on mode, instead having to go cell by cell... but that doesn't mean the only way to do partial throttle mapping is by hand. It just means the guy doing the mapping needs to A) understand what he's doing and B) be willing to put in the time to do the job properly, not just a couple roll ons and call it good.
    Re: Custom map
    Insurance rates are different!
    Infected Slyder's Avatar
    Concord, NH
    Re: Custom map
    Bazzaz...
    Or Motty's AFR tuner Motty AFR Tuner
    Power commanders and dyno tuning is obsolete. Wide band tuners that do the tuning themselves...that's where it's at. wanna run race gas? top the tank off and ride the bike, it'll do the rest. want to drop in a jacked out set of cams? go for it, ride it to tune it. wanna ride out west and change 5000 feet of elevation in a day? ah, just go. she'll tune herself.
    With the PC and custom map, it's good for that day, when its done. what happens tomorrow when it's 20 degrees colder and no humidity?
    For the cost of the PC and a dyno tune, you can spend another $100 or so and score a wideband AFR tuner
    Re: Custom map
    Yup, you are so correct.
    It takes more than 15 minutes...
    I even tweeked bikes that were done with the tuning link as well. There are just factors that can't be duplicated as well as if you were running on the street.
    Re: Custom map
    Quote Originally Posted by Slyder27 View Post
    wanna run race gas? top the tank off and ride the bike, and your expensive lambda sensor will be smoked before your next fill-up.
    Fixed it for you, race gas and Wideband O2 sensors == BAD COMBO.
    Re: Custom map
    It's what your brandy new bikes are doing now with total closed loop systems...The only problem is they are running against parameters that the EPA set for them....
    Re: Custom map
    Yeah, leaded fuel and oxygenators have their place...
    Re: Custom map
    Oh yeah, and who's accusing me of running a Motec box on my TLR?
    You mean the TLR isn't supposed to redline at almost 12,000 rpm's?
    Concord, NH
    Re: Custom map
    $48 is expensive? and all race gas is leaded?
    So someone start reprogramming the ECU's and lets make Bazazz and Motty's AFR tuners obsolete
    How does the OEM o2 sensor manage to work correctly then? Wouldn't you still need a wide band sensor?
    Re: Custom map
    it all depends on how "wide" the stock o2 sensors read.
    Lifer BostonSVkid's Avatar
    Dec 2005
    Re: Custom map
    Hey Mark
    Once I get my trumpet sorted out I will be coming to you. I am having a running issue that I think dealer may have to sort out.
    2006 Ducati Monster S2R800
    Re: Custom map
    Hey Mark
    No problem buddy...should have bought a Gixxer...
    Concord, NH
    Re: Custom map
    Well, on the gixxer 1k, at least the 07+ that sensor, from what I heard, does nothing more than tell the ECU the cat box is hot. You can jump it out, remove it, throw it in the trash where it belongs and the bike will run the same as it did before you removed it.
    Yea, it's not exactly wide. It's pretty damn narrow
    Re: Custom map
    The problem is emissions....Dynojet paid a hefty fine because the PC's were able to alter the fueling enough to make the bikes "dirty". Enter the "Green Powercommander". But as everyone knows, dirty, sometimes means a better running engine. You know as well as I do that 14.7:1 AF ratios don't make good HP.
    Dec 2005
    Re: Custom map
    Yeah yeah I know. I think I am dealing with a bad coil, tps sensor or something.
    Think you could figure it out? I would rather give you my money haha.
  1. Replies: 12
    Last Post: 10-18-12, 09:39 PM
  2. Custom Bike
    By jcrawford in forum General Bike Related
    Last Post: 08-09-12, 11:48 PM
  3. 2001 CBR 929RR Single Sided Swingarm, custom custom custom
    By customfighterer in forum For Sale
    Last Post: 06-29-10, 02:03 PM
  4. Sweet Custom Kaw
    By csmutty in forum General Bike Related
    Last Post: 01-16-10, 02:05 PM
