Results 1 to 25 of 25
Need a tire plugged
    Lifer greenmonster's Avatar
    Aug 2003
    Need a tire plugged
    Got a "nail" in my rear tire. Not sure if its a small nail or thick wire...there's no flat head to it, just the shaft. I tried the soapy water spray, but I'm not positive about seeing any bubbles, besides those from the water! And that doesn't mean it wont leak once the thing is pulled. Dont wanna chance a flat in the middle of nowhere. What I'd like to do is plug it while still on the bike, if thats possible, using a "mushroom" type of plug. If it needs to be from the inside, Jeff has offered to dismount it for me, and I can bring it to whomever. I live in Waltham, so ideally I'd like to bring it to anyone who lives closest. I'd rather pay someone from here with the experience plugging tires than a dealer. Next spring I'll get new skins from Jeff, but for now, I'll go with a plug. Thanks!
    Foxboro, MA
    Re: Need a tire plugged
    pay trickphoto to repair it and mount it back up! right in the area
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Jun 2005
    I can hook it up. It'd be $35 in labor plus $5 for the plug. You could just ride over.
    You want to stay away from the mushroom plug, though...
    This is the only way to fly:
    Some kind of tube RupturedDust's Avatar
    Pardon my ignorance, but what's wrong with the mushroom plugs?
    Enjoy life! There's plenty of time to be dead.
    2002 Suzuki SV650 Nekkid
    http://www.squidbusters.com
    Jun 2005
    The plug/patch type numbers (like the one pictured) bond to the inside of the tire via vulcanization with a whole bunch of surface area.
    Mushroom plugs (at least the ones I've seen) rely on the compression of the rubber plug to hold it in place.
    Gotcha, thanks!
    Aug 2003
    Quote Originally Posted by trickphoto View Post
    Sounds good, Mike...PM sent...
    Slut scorp7's Avatar
    Rhodailand
    I too am looking for this, but the one place I found that would patch the tire, does not use this type of patch/plug. Is it something I can buy at Pep-Boys or Walmart?
    Jun 2005
    Not very likely... PepBoys maybe. I think I found them at a NAPA in Arlington, but had to call a million places before I found someone who had them.
    Don't forget the vulcanizing fluid.
    Lifer DuncanMoto's Avatar
    +1
    Everything has its purpose. A mushroom plug is meant as a temporary plug ONLY. You should go no more than 50 miles and then have trickophoto plug it from the inside.
    Rhodailand
    Found it. Napa is the place : ) For those interested it is
    Part # 7101642. Thanks a lot guys!!
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    take the hole give it a good reeming then ookumpooky the shit out of any plug your using........
    www.bostonmoto.com
    Forum Rules
    Blingaphobe Devil1's Avatar
    May 2007
    Maine
    I'll never plug a motorcycle tire. Who wants that thing to blow apart, or fall apart while at speed???? Not me buddy. I value my life more that a 5 dollar plug.
    MSF RiderCoach
    May 2002
    Meriden CT
    He's right new tires never fail, get a new trustworthy $100-200 tire.
    Quote Originally Posted by Devil1 View Post
    www.bostonmoto.com
    Forum Rules
    Mar 2004
    woonsocket ri
    Quote Originally Posted by beet View Post
    Would you like some Firestone Wilderness tires?
    Rhodailand
    I keep getting getting reviews. I called some places that still only plug the tires. I agree w/ buying a new tire, but I don't plan to do much more riding for the rest of the season, so this is a temporary solution. New tire next year.
    Rhodailand
    About that, I keep seeing the Michelin Pilot Power tires being recommended, but I read an article where they were recalled. Was that for an older year?
    what is the big deal if your tire fails ? are you hamfisted. I'm sorry you don't know how to handle your bike in an emergency situation, what would happen to you if you ran over a road hazard, maybe you shouldn't ride at all
    I value my life more than a plug too, but one doesn't have anything to do with the other
    BTW, if yer paying $5 for a plug, yer getting ripped off, you can buy a package of 5 for $3.99
    KB KB's Avatar
    Manchester NH
    I'll plug a tire with the 3.99 noodle job and ride it till I need a new one. I have never heard of anyone dying from a plugged tire.
    I'd even plug and RACE a tire. Ohhhhhhhh the taboo!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    May 2007
    Southern NH
    Quote Originally Posted by rmbbikes View Post
    +1 me too....ran a whole season on a Pilot 2ct plugged with a noodle job. Didn't leak at all and the tire was COOKED when I took it off.
    It helps to understand a little bit about what we are talking about.
    When you use that little tool to ream out the hole you are actually sawing through 'cords' in the tire plies. Most tires are two, three or four plies and many include belts (plies that run under the treads but not bead to bead.
    This sounds bad but actually you are not really damaging the overall structural soundness of the tire since all the rest of the cords are intact. A much more profound problem is if you have belt separation. You can often detect this buy putting the bike on a stand and spinning the tire slowly. If you can detect a 'wobble' you likley either have a bead that's not properly seated or a separation in the plies. I would immediately replace a tire with a PLY separation as catastrophic failure is much more likely in this case than in a case where a tire is plugged. The worst that can happen there, even it the plug itself fails completely (highly unlikley), is a loss of air...not an explosion.
    BTW...you might want to take a tire and read all the information that is required by DOT to be included. Every tire has a fairly detailed description of the construction...
    A Metzler 180/55 ZR 17 ROADTECH Z6 has one Rayon Ply with cords running radially, bead to bead and one additional STEEL ply under the tread. So it is essentially a 1 ply steel belted radial. Its max load is 1805 lbs at 42 psi and is a Load Range B.
    There is lots of other information such as month and year of manfacture and a cool little picture of an elephant...
    But, you should really go and buy a new tire because I am not an expert and wouldnt want you to put your life in my hands...
    ...me, I'll run plugged tires. At the speeds I ride it doesn't really matter!!!
    Muhammad Ali.
    May 2007
    Southern NH
    Quote Originally Posted by scorp7 View Post
    Yes...that was two years ago?? That run should be long gone...
    Muhammad Ali.
    KB KB's Avatar
    Manchester NH
    This is kind of like the old motorcycle specific oil debate.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    May 2007
    Southern NH
    Or God vs No God....
    ....its a religious discussion
    Muhammad Ali.
    May 2002
    Meriden CT
    KB = Joe six pack
    www.bostonmoto.com
    Forum Rules
    KB KB's Avatar
    Manchester NH
    Beet = not quite sure!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. For Sale - Services | $10/tire change + dynamic balance - June 2021 tire changing blowout special (hah)
    By PurplePackage in forum For Sale
    Last Post: 06-24-21, 03:00 PM
  2. For Sale - Parts & Tools | Harbor Freight tire changer with motorcycle tire attachment
    By -Dutch- in forum For Sale
    Last Post: 06-21-15, 11:31 AM
  3. Woodcraft Digital Tire bakers tire warmers NEW
    By DuncanMoto in forum For Sale
    Last Post: 08-16-12, 08:59 AM
  4. Harboir freight tire manual tire changer
    By black in forum For Sale
    Last Post: 09-22-10, 11:38 AM
  5. Track Day with plugged tire - who's done it?
    By hohum in forum General Bike Related
    Last Post: 09-07-04, 02:28 PM
