Results 1 to 9 of 9
Weird master cylinder Q
    Nov 2007
    I cleaned my calipers/pistons, put in fresh new pads, and put in new fluid with a lot of fluid bleeding.
    I noticed near the bleeder there was some fluid, I assumed I spilled it during the work.
    I can put a ton of pressure on the lever and I don't see anything at the master. I even tried lots of quick hard pulls and releases on the lever and don't see anything.
    Then, when I push the little rubber protective cap onto the bleeder, right around the joint/threads between the bleeder and the master, I hear a little psssst and see some fluid pushed out. What does this mean?
    Yes, I made sure all the bleeders were nice and tight in there.
    By the way, this is a speedbleeder, I have them in all three locations. I replaced with those when I put on the stainless lines and new pads a while ago.
    I have never quite been able to get as stiff of a lever pull as other people and I'm wondering if my master cylinder is fucked.
    By the way, I have extremely limited spare time between now and thursday, I hope someone can tell me this isn't a problem or it's an easy fix
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Lifer union's Avatar
    Blackstone, MA
    Re: Weird master cylinder Q
    My stock master also feels a bit soft. Maybe its a yamaha thing.
    The noise sounds like you might have a little fluid left over in the bleeder. When you push the rubber cap on the air between the cap and the bleeder builds up a little pressure and forces out some of the left over fluid.
    James
    Zip tie the lever to the bar and leave it overnight, it always made a huge difference on my bikes
    Raymond NH
    I've never heard good things about speed bleeders. I would put the OEM bleeders back. I have nevre been able to get a good lever feel by bleeding with the master cylinder pressure alone. The problem is you are trying to push air bubbles to the bottom of the hydraulic system and the air bubbles, being much lighter than brake fluid, always rise to the top of the hydraulic system.
    I bleed with a mity-vac, which seems to eliminate the air bubble nicely. If you don't have one, remove the calipers (leaving brake lines attached) and get someone to hold them up as high as possible while bleeding. Let gravity help rather than hinder.
    Nov 2007
    But the fluid gets pushed out down near the junction between the master and the bleeder... i.e. by the threads. This doesn't seem right to me? The brakes work fine and seem to hold pressure just fine... but this irked me a bit.
    Well I have speedbleeders on the calipers and on the master and I've always had good luck with them... do the master, do the calipers, do the master again. I think the sponginess is just the OEM master... and it's very slight.
    My concern was more the little bit of fluid pissing out when I put on the rubber cap... just seems weird to me but everything seems to function fine
    LRRS/CCS #103
    Lifer Pittenger5's Avatar
    Austin
    Putting the rubber cap on probably just forces some of the fluid back thats left in the doohickey. Being that it has nowhere to go from the pressure, it squeezes out through the threads. Going out that way probably isnt bad, if it was coming from your lines Id be worried.
    (note, I dunno what a fucking speed bleeder is, but if its the way I think it is that might be what the problem is.)
    Zip Tie Alley #505
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Chris,
    I had the EXACT same issue with my bike the first time I changed the brake fluid. It's normal. Check out my gixxer.com thread about it.
    http://www.gixxer.com/forums/showthread.php?t=129316
    Nov 2007
    Quote Originally Posted by Billy View Post
    Chris,
    Wow thanks Billy... that really puts my mind at ease
    Makes sense
    LRRS/CCS #103
    Feb 2006
    Metro West, MA
    No problem man!
  1. Wanted - Parts & Tools | R6 master cylinder
    By Johnpewpew in forum Wanted
    Last Post: 03-13-19, 09:37 AM
  2. Wanted - Parts & Tools | 08 CBR600rr OEM master cylinder
    By Pittenger5 in forum Wanted
    Last Post: 11-25-15, 09:46 AM
  3. Weird brake bleeding/ master problems
    By maxim_X in forum Bike Maintenance
    Last Post: 06-06-15, 07:51 AM
  4. wtb master cylinder
    By hondarider102 in forum Wanted
    Last Post: 05-23-11, 10:25 AM
  5. Think I F-ed my master cylinder
    Last Post: 02-16-08, 08:23 PM
