Results 1 to 12 of 12
Warning Labels!
    Junior Member SickR1Rider's Avatar
    Apr 2005
    Exclamation Warning Labels!
    Ok, I have an 03 R1. How the hell do I get off the warning stickers from the tank without leaving a big mess??? I started to peel one, but it looks like shit!!!
    Some help...
    Lata,
    Pat
    Warning Labels!
    Hair dryer
    Re: Warning Labels!
    Some help...
    Lata,
    Pat
    I think THAT'S A SERIOUSLY DANGEROUS THING TO DO, without the warning sticker, you might forget and ride without a helmet or proper gear, you might also consume alchohol or other drugs, it's also a bad idea value wise, you bike will lose half it's value if there is any original equipment missing,
    why do peeps remove stickers anyway?
    Warning Labels!
    hair dryer & goof off or some kinda crap remover.... Goof off, Bug remover whatever works
    Resident Chrome Dome Cue Ball's Avatar
    Johnston, RI
    Warning Labels!
    Little bit of heat w/hair dryer, than remove jizz with WD40. Remove wd40 with car wax, good as new.
    All I want for Christmas is another rear tire.....
    http://www.ratemythong.com/indexhome.php
    Just Registered
    Is it not obvious?
    Warning Labels!
    ..as long as nothing's under the clear:
    -1500+ watt hair dryer hi fan+hi heat, keep it moving, start peeling at one edge. Once you get it, heat the area just south of the radius of the peeling area...all set.
    -Try not to scrub or 'buff' until you're cleaning up the area post adhesive.
    -Go to the painting or auto detail section of walmart and guy the goo-gone spray gel (silver spray bottle about 1/2 the size of a normal one) this works the best in my experience.
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Resident Bosox Aficionado mikem317's Avatar
    May 2005
    Warning Labels!
    I use GooGone for crap like this. Removed a ten-year old pin stripe on a car with that and a carefully aimed hair-dryer. Washed and waxed afterward. Seemed to do the trick.
    Regards,
    Mike
    Where were you on October 27, 2004? // Got Wallpaper? // Special Discount for Boston Red Sox Fans! // Because even Alex Rodriguez has feelings too...
    "Everytime I see a Yankee's hat, I see a swastika just a little off kilter." -- Bill "Spaceman" Lee
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Warning Labels!
    swear at it a couple of times then stomp your feet on the ground
    Mar 2004
    woonsocket ri
    Warning Labels!
    sometimes you gotta kick it too just to get the tough ones off.
    NESR ruined my life. chr|s sedition's Avatar
    Aug 2004
    I ride...someone else's bike.
    Warning Labels!
    wheveryone else said....hairdryer and Goo Gone. However, i might add that Goo Gone comes in different strengths. some of the really strong shit can alter paint finish a bit. Go for the "citrius" stuff and should be fine. Just real the labels to make your getting the approprate stuff.
    -chr|s
    "Up front there ought to be a man in black." -John Cash
    LISTEN TO SLAYER
    If I get another fuckin' bike stolen...
    Warning Labels!
    that's one of the reasons why i use bug remover... easy on the paint
    Warning Labels!
    Usually with a hair dryer, you won't leave any glue residue.
    I use this stuff called "goof off" if i do have to remove some glue though and it's never hurt the paint.
    Mineral spirits works good as well and won't hurt the paint, it also does a very good job of cleaning chain fling stuff off the bike as well
  1. Rider Labels
    Last Post: 04-22-08, 02:46 AM
  2. RT 153 Warning
    Last Post: 11-17-05, 03:59 PM
  3. LEO WARNING
    By SVRACER01 in forum General Bike Related
    Last Post: 07-05-05, 04:16 PM
