Results 1 to 19 of 19
Wheel & Swingarm Bearing Removal tool
    High maintenance priss
    Central MA
    Anyone recommend or know of a good bearing removal kit available that will remove most wheel and swingarm bearings? I do know that bearings can sometimes be pounded out from the other side. I've found that some bearings, like the needle bearings on the TLR swinger, can't be removed via this method.
    I've read that the more generic internal z-type pullers aren't great (can slip & cause damage)...that the case?
    This kit by Motion Pro seems like it might do the job. Thoughts?
    Or are bike/mfr-specific tools really the way to go for this type of job?
    KB KB's Avatar
    Manchester NH
    It's called a socket and extension and a hammer.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Waterbury, VT
    If it's got a good lip on it I use a brass drift and a ball peen hammer from the other side. I've seen threaded pullers with collar systems as well as the slide hammer system you found. $188 is a lot to invest if you're not doing it that often. In places where special tools are required to get the job done I'll take the swingarm or other part off the bike and take it to the shop and have them do it.
    SSearchVT
    Central MA
    Quote Originally Posted by rmbbikes View Post
    For installing, yeah. But theres no way that would work for removal...not when the design doesn't allow for the bearing to be punched out from the back side.
    Lifer ZX-12R's Avatar
    Candia, NH
    The one time I had to remove a blind bearing, I borrowed a tool that my neighbor had made from scratch. He started with a long brass drift and bent the end of it over 90 degrees and partially peened it so it would have a larger surface area. He then then threaded the end and machined a mating plate that threads onto the brass drift giving a flat striking surface. When he uses the tool, he takes a heavy impact socket and slides it onto the drift and then screws the plate on the bottom making it a slide hammer. It's not as efficient as a collet type remover since you have to work the bearing in a circle but it didn't cost him a thing since he made it out of scrap he had laying around.
    If you don't want to make one, I found a slide hammer kit with 8 collets for about 80 fewer clams:
    Sir Tools - SIRST9006 - 8 Pc. Blind Hole Bearing / Bushing Collet Set with Slide Hammer - DealTime-Direct.com
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Not positive what your swingarm looks like, so its tough to reccomend a tool. Is there a hole straight through with a lip retaining the bearing, or is it completely blind (only accessable from one side)?
    You can make a bearing press with some threaded rod, a few nuts and washers, and two sockets. (Its what I use to change swingarm bearings). All parts availible at your local home depot or hardware store for around 5$ and some change.
    Again though, this may not work, as I have no idea what your swingarm looks like.
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by rebelpacket View Post
    I have a home made wrist pin puller that i made the same with a pice of electrical conduit.
    Dude we need to open a MC shop service!!! Wanna move to NH and live in my basement? We can convert my 10x12 shed into a workshop.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jul 2003
    Bozeman, MT
    Lets do it. Name of the shop could be "Tards with Tools - We'll fix it, or break it trying." As long as you don't make me pay the rent horizontally, I'm down.
    Foxboro, MA
    PWND
    (i think)
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by Smooth R6 View Post
    PWND
    (i think)
    I'll punch a bearing out from the backside like it's my yob.
    Yeah I said Y O B.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Central MA
    Will your backyard shop have insurance?
    KB KB's Avatar
    Manchester NH
    Yup. Brake light insurance. As soon as I can't see your brake light the insurance is up.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Oct 2007
    Peabody Assachusetts
    I'm gunna throw my 2Cents in here and you guys can hang me out to dry if ya want. I do not like to punch a bearing out using a hammer and blunt rod.
    The bore of the wheel vs the o.d. of the bearing is a close tolorence. Which means the bearing really needs to come out straight. By punching it out from the back, the bearing does not come out straight. The bore of the wheel can get oblonged or stretched if you will. This IMO, is not good.
    And no, I'm not talking out of my ass... I been in the machine shop buisness for 22 years.
    I'm not saying you "cant" do it, but it is definately not for me....
    Another Busa Riding Troll CAT3's Avatar
    Oct 2007
    Pueblo West, CO
    I agree with Bren on this one. Out of round race surface will allow the bearing to rotate in its housing, the wheel or swingarm, and will eventually fail. Can it be done, yes, recommended, no.
    Also, do not use a brass drift with bearings. The brass is too soft and will splinter however minute, those little splinters work their way into the bearing race and bearing and cause pitting or scorching. Use tool steel if you insist on punching the shit out.
    Or, you can successfully use a this tool set, much cheaper than those posted and works very well. Or the slide type, here.
    The Big CAT rides the fastest bird!
    Only two defining forces have ever offered to die for you, Jesus Christ and the American GI. One died for your soul, the other for your freedom.
    Central MA
    Quote Originally Posted by brendanp View Post
    I'm not saying you "cant" do it, but it is definitely not for me....
    Do ya have a good universal-ish type of remover that you recommend?
    CAT3 - Thanks for the links! One type generally better than the other (slide vs. jaw)? I can see the jaw/screw being slower & more controlled. But I'd think small jaws would be prone to slip.
    Oct 2007
    Nope...believe it or not, that 14 dollar one from harbor that Cat3 posted will work just fine. The bore to bearing fit is not extremely tight.
    Posting Freak
    New Hampshire
    Quote Originally Posted by CAT3 View Post
    You should never re use a bearing that's been pounded out anyway.
    Candia, NH
    Quote Originally Posted by Ryno View Post
    And you shouldn't be hitting the brass drift so hard that it would sliver.
    Lifer Wishbone's Avatar
    Jul 2006
    Plus who the hell has a bike long enough to replace a bearing?
    Mine are always in the salvage yard from stunnin way before that
  1. Wanted - Parts & Tools | Any one have a Wheel bearing removal Kit........
    By Pigman in forum Wanted
    Last Post: 03-28-15, 06:04 PM
  2. Chain Breaker & Bearing Removal Tool
    By BigShel in forum For Sale
    Last Post: 08-09-11, 10:38 AM
  3. Powder coat prep and bearing removal.
    By clyons in forum General Bike Related
    Last Post: 12-26-09, 10:45 PM
  4. Steering bearing removal...
    By dwaltz61 in forum Bike Maintenance
    Last Post: 08-26-08, 08:26 AM
  5. Bearing Removal.
    By oreo_n2 in forum Bike Maintenance
    Last Post: 10-03-02, 09:29 PM
