Results 1 to 25 of 28
Winter Rehab on my 2002 blackbird
    Jan 2012
    Lowell
    Hey, bought this bike in July of 2011, had been dropped in a driveway. It had power commander 2, two bros slipon, a mystery 4 -2 - 1 exhaust system (please look at pictures and see if you can help me identify), chrome wheels, polished frame, cut undertail, and a couple other mods.
    This winter is my first opportunity to really clean up the bird and do all the maintenance I've wanted to do since I bought it. It is my first bike and I've put about 6k on her. I want her to look pretty much pristine. All I did when I bought it was Michelin Pilot Powers and GN4
    So far I have done:
    Oil (GN4)
    Oil Filter (K&N because of the nut on the end)
    Spark Plugs (NGK IMR9A9H)
    Air Filter (Stock Honda):
    Coolant (Honda HP)
    Sand clear coat and polish carbon fiber 2bros slipon as it was scratched and marked from the bike being dropped, it got three coats, gonna sand in a few days
    Detail bike with plastics off
    Removed rear wheel degreased entire rear swingarm, rear sprocket, and polished the chrome wheel.
    polished my frame up to remove oxidation
    polished the swingarm to remove oxidation
    before:
    after:
    cleaned my chain with kerosene and lube it (little rust)
    Painted stator and clutch cover as when the bike was dropped these got scratched. Went 2 coats high temp, 3 coats clear
    New bar weights
    HIDs
    I also plan on doing:
    Previous owner put on cheap ebay turn signals and cut the undertail, so I will be making his cut cleaner, filling in the turn signal holes,
    and installing this:
    New Plastics, I plan on going with ebay plastics:
    Pyramid Seat cowl:
    It came with the decals slightly bubbled, and a small paint imperfection, but it's a pain to send it back so whatever.
    New Windscreen (Mine was imperfect):
    Questions:
    What Kind of exhaust is installed on the bike (I know the slipon is a 2bros but the actual headers to exhaust)?
    How the hell should I go about fixing my undertail? I want to add a 1/4 inch to the bottom of where the last owner cut, fill in all the holes (including the turn signal holes) and make it look flat... ideas?
    Anything else I should do or check or do differently? Any other ideas?
    Senior Member mell0's Avatar
    Manayunk, PA
    Re: Winter Rehab on my 2002 blackbird
    Pictures aren't working?
    -Andy
    2013 Triumph Bonneville
    Jan 2012
    Lowell
    images fixed (i think)
    Manayunk, PA
    Yup! Thanks
    -Andy
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Welcome to the forum. That's a hell of a first bike to pick up.
    The headers are probably stock. Have you compared them to stock?
    As far as the under tail you can probably find an OE piece on EBAY. But I don't know many ways to fix the plastic.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Jan 2012
    Lowell
    Stock is a dual exhaust, and looks way different... I'm hoping a blackbird expert will be able to help me figure out the brand.
    as far as a first bike, I just had to understand what I was capable of, and not put myself in a position to do more than that. Others would say I got lucky.
    Douglas Ma
    I dont know if you've tried here but these guys might have more answer's for you...good luck, nice ride. http://www.cbrxx.com/
    Jan 2012
    Lowell
    Quote Originally Posted by bstnsboy View Post
    thanks, yeah... I'm on there as tomfraser
    hopefully it looks good when I'm done, I'm putting the work in lol
    Lancaster
    I think i met you one day in Lunenburg, i was on the Black and Maroon CBR600RR fighter!
    Jan 2012
    Lowell
    yeah... that was a fun short ride lol
    Once it's all together we'll have to go riding sometime, I got a couple friends I go to school with that ride, a 2007 zx6r, cbr600rr, an f4, etc.
    You do anything new to your bike?
    Lancaster
    Quote Originally Posted by blackxxbird View Post
    not yet, i have some ideas for the winter but we shall see if i get around to it or not. ya def in the spring well have to get out and ride
    Westford, MA
    Sweet! Can't wait to see how this turns out!
    ...I have your pants!!!
    CT
    Nice job on the XX, they are fantastic machine. Honda started the wars back in 97 and while it no longer is the raging beast compared to the busa or 14r, it still is a terrific bike. I had a 97 xx,yosh rs3 4-2-1 carbon pipe, jetted by ACS racing and the bike made 143 rwhp. Back then it was fast compared to the other bikes, the one thing I still remember is how refined the bike was, smooooooth as glass on the highway.
    The design and looks of the XX still make it look new by todays standards.
    Good luck with your XX...your going to grow to love the bike.
    Jan 2012
    Lowell
    Already love it lol, I can't wait to get her back together, and then I'll be just as anxious for some warm weather
    who knows
    You will need to let me know how this holds up. Did you use a high heat clear coat? I have a similar two bro's exhaut and the carbon fiber has lost it's luster.
    I was going to buy a can of High heat clear coat because I figured it still got too hot for regular clear coat paint?
    Jan 2012
    Lowell
    Finally got motivated to get her back together
    Some things I figured might help others out to know that I learned along the way...
    Ebay plastics are great for the race bikes, do not buy them for bikes like this with lots of plastic... I ended up drilling my own holes, gluing nuts to the plastics as they were not threaded for fairing bolts, doing some plastic work to move brackets around, and just in general doing a lot of work to coax it into position. Some pieces did not fit so I was forced to use old ones.
    The integrated turn signal was not a direct hookup, I had to wire it in a funny way that I've forgotten since I did it, but If anyone needs a howto just ask and I'll take her apart and look.
    The ebay HID headlights are one of the best purchases I could have made... I can see EVERYTHING and the high beam lights up the entire highway.
    So far the painting of the stator and clutch covers has held up nicely to heat, the two brothers exhaust carbon section looks good, but I sprayed the metal part which gets hot and this is turing a copper looking color... doesn't look bad but just a note.
    After refreshing her coolant the bike runs 5 to 6 degrees colder, but I really want to test in the summer as the blackbird was running up to 230 then, which everyone said was normal.
    I did notice that she was more happy (than I remember) to pick the front end up just from twisting the throttle after doing the plugs and air filter, I guess the old plugs were old and bad quality and putting in new expensive ones is the only reason I can fathom this
    I will post more pictures when I get a chance, but I took a few below at some nice twisty, closed roads.
    Aug 2009
    Nice pic, Myles Standish, right?
    Dublin, NH
    Looks good except for those HIDs. Please do oncoming traffic a favor and take them out, or paint the shroud and retro a projector. Using HIDs in halogen reflectors scatters the light everywhere and blinds oncoming traffic.
    2023 KTM 890 Adventure R
    Jan 2012
    Lowell
    yep, one of my favorite places to be (have a cottage in there).
    as far as HIDs I'll have to look into what others have done see what my options are
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Very nice. I have a 97 ZX 11 in silver but always wanted a blackbird so I`m a bit jealous. They were the "speed kings" that year and I think the Blackbird edged out the Ninja by a MPH or two back then. I`m up for a dyno drag if they have one this year at MN. Ha ha Good luck with her
    Jan 2012
    Lowell
    Quote Originally Posted by ZX11D View Post
    I'd love to see what the bird is putting down for power, hopefully I'll get her on some type of dyno this summer.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    threaded plastics don't they screw into brackets and well nuts?
    Jan 2012
    Lowell
    About half of them do... the bolts that connect the lower fairings to the front nose cone do not, they had a clip on the back that the bolt would thread into, the ebay plastics have no way of holding any clips
    Bridgewater, MA
    gotcha. figured that's what the stock ones were like but didn't know about the ebay stuff.
    Rindge NH
    Nice looking bike. Looks very similar to my ZZR. My last bike purchase was a toss up between a blackbird and a ZZR1200 i got the ZZR, at the time i couldnt find a Blackbird to look at. Hope to see at MN sometime, I bring the ZZR or the KZ1000 most tuesdays. JT
  1. Replies: 0
    Last Post: 08-31-16, 02:09 PM
  2. Replies: 8
    Last Post: 11-25-13, 07:58 AM
  3. 1998 Honda Super blackbird CBR1100XX
    By soshoresig in forum For Sale
    Last Post: 02-27-12, 12:57 PM
  4. 1998 CBR1100XX Super blackbird
    By ri.blackbird in forum For Sale
    Last Post: 06-01-11, 06:57 PM
