Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Old Worn Chain clanking - Advice on urgency of the problem
    Re: Old Worn Chain clanking - Advice on urgency of the problem
    The only reason I asked, is you wanted a recommendation on where to go. I'm pretty sure Jane uses a place in Westport. I'll defer to her:
    WD40 is an expensive way to clean a chain, Kerosene is cheaper AND what most manufacturers recommend
    if its not spinnin freeley and sprocket teeth are visibly worn replace and as allready recommended, replace everything
    chains & sprockets last anywhere from 5000 to 60,000 miles or more depending on yer riding style, environmental conditions and maintenance
    I run a scottoiler with ATF and a 530 chain instead of the stock 525 chain on my V-strom
    front sprockets gets replaced about every 20k-25k, chain & rear sprocket every 45k-50k
    I know, that goes against the recommendation of replacing everything at once
    most people wear everything evenly, fer some reason, my ridign style, I chew thru front sprockets compared to chain & rear sprocket
    Lifer ZX-12R's Avatar
    Candia, NH
    i have always been told its bad to use and dries out the o-rings so i have never used it, i did some research on it and it seems its not bad to use, sorry for the false info, it was just what i was always told by more then 1 person
    I use it as my only form of chain lubrication and I'm up over 26K on my current chain and sprockets.
    Custom User Title Dichotomous's Avatar
    Jan 2007
    Jericho/Underhill
    its not that wd40 is horrible, its just not ideal really. fine to spray on and wipe off, but horribly expensive to do so. then again, its easy, and you'd have to set a spray bottle with kero, though kero works better, or diesle
    theres just something about a blue bike
    Lifer Stromper's Avatar
    Eastern Ct
    wd40 I think is fine.
    It has a light oil that evaporates and leaves a waxy deposit. On very fine mechanisms its not recommended because the "oil" has gone away and the waxy stuff holds dirt particles.
    On a MC chain thats fine
    The best would be rear end lube 90 or 120 wt high sulphur gear lube but it stinks and makes a mess
    Jan 2007
    Jericho/Underhill
    funniest part about mc chains is that they are smart enough to include a full coverage and often enclosed chain guard on scooters, but can't seem to make the leap that it would be good on full size bikes
  1. Some help/advice on a new chain
    By rice_rocket in forum Bike Maintenance
    Last Post: 10-02-12, 11:22 PM
  2. Chain tool advice
    By viffer57 in forum Bike Maintenance
    Last Post: 09-14-12, 10:02 AM
  3. Chain and Sprocket Advice...
    By Femmekat in forum General Bike Related
    Last Post: 01-18-10, 09:00 AM
