Results 1 to 20 of 20
2001 GSXR 750 head
    2001 GSXR 750 head
    I believe 2000-2003 are all the same.
    Must have good exhaust bolt mounting holes/threads.
    Re: 2001 GSXR 750/1k head
    I thought the 1000 head was different from the 750 head? The 00-03 750 was all the same.
    You are correct. I can use a 2000-2003 750 head.
    Re: 2001 GSXR 750 head
    what did you do?
    Quote Originally Posted by LXnastynotch93 View Post
    incorrect. they have the same part number. 11100-35F00
    http://www.ebay.com/sch/i.html?_odkw...+2001&_sacat=0
    what did you do?
    Header bolts were frozen so bad that an EZ-Out, welding a nut on, drilling out, etc all didn't work.
    Register for high temp anti-seize for your wedding, cause that's what I'm getting you.
    i dont need that shit. came off without issue for me when i changed that header almost 10 years ago
    Member THE STUFF 187's Avatar
    SWANSEA MA
    I have a complete good running engine I would sell you for $750
    Adrenaline Cycle
    Swansea,MA
    Dyno Jet Tuning Center
    Apparel
    Fabrication
    Powder Coating
    Paint
    Service
    Engine service
    Race Bike Prep
    Used OEM Parts
    Track bike rentals
    ADRENALINECYCLEINC.COM
    Like us on Facebook
    [IMG]http://www.facebook.com/AdrenalineCycle1?ref=hl
    Quote Originally Posted by THE STUFF 187 View Post
    I have a complete good running engine minus two header bolts I'll sell you for $650 if I buy your engine.
    Just looking for a head at this point.... she runs great, just those bastard bolts. Worst part? Just did a valve check and ALL of them were in spec.
    Clayton- how many miles are on your GSXR? Mine just hit 22k at the track yesterday. Still runs mint after 41 track day.
    About 27k I think?
    12 of those miles are mine!
    Really, just rode it to the gas station and that's it. She'll be a dedicated track bike once I get everything done to it that I want to get done.
    No longer need a head. Got a good condition one with cams/valves/cover/intake boots/sensors/etc for under $90 shipped.
    5 Not allowed! Not allowed!
    Bump. Finally went to install the head. NOPE. Looks JUST like the original. Only odd thing is that the frame mounting hole is about 1/4" off. And the coolant nipple is in a different spot.
    So, it's not the right head. Looks like a head from a 2008 1000. Mother fucker.
    Looking for a head. Damnit.
    Haverhill, MA
    Is there not a machine shop near you that could repair the old one?
    If not one near you then Harry's Machined Parts in Northborough MA has done a ton of interesting work for a friend that builds some silly bikes.
    To repair the old one, they would have to cut off some aluminum and put new stuff on, then machine the surface and drill/tap.
    I'm thinking it's likely cheaper to buy a used one for $70.
    Haverhill, MA
    I didn't figure you could find a used one in good shape for cheaper than the repair. I guess if they can be had that cheap than yes buying one is the better option.
    Found one.
    Still looking. Apparently EBay sellers think it's ok to ship a head with the cams loose bouncing against the head with no padding in the box. Wtf.
    Maybe just me, but I would have gone the repair your current head route before searching eBay or Craigslist. You know you have a good working head, why waist time and effort sorting through junk and trust someone else's word...which has failed you twice already?
    Guaranteed good head is on it's way.
    I'd be curious to see how much it would cost to fix the old head. It would involved cutting off aluminum, welding new stuff back on, then machining down a clean surface, then drilling/tapping. All right next to the exhaust port. Twice. I'm betting it's more than I'm spending on a decent used head by a BIG margin.
  1. Parting Out 2001 GSXR 600
    By TurnOneGraphics in forum For Sale
    Last Post: 10-05-13, 05:17 PM
  2. 2001 GSXR 750- $4500
    By Lxpony in forum For Sale
    Last Post: 08-19-13, 01:21 PM
  3. 2001 gsxr 600 front rim
    By burtonboarder23 in forum Wanted
    Last Post: 10-14-12, 05:46 PM
  4. 2001 Suzuki GSXR 750
    By Mystic in forum For Sale
    Last Post: 05-11-10, 06:42 PM
  5. 2001 GSXR 750 Forks
    By BostonSVkid in forum For Sale
    Last Post: 10-22-08, 09:11 PM
