Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Want free firewood
    Re: Want free firewood
    Hickory
    Yes, I'm offering for you to come up and get your own firewood. In fact, if you hurry I've got a coupla nice stacks of dead tree tops just waiting for someone to come cut up and take away...
    That being said, let's clear something up. It's not type of wood, per se that can cause chimney problems. Rather it's a constant cycle of cold flue - warm flue - cold flue - warm flue. You can burn anything you want so long as you can keep your flue at a consistent temp without worry. Condesation is far more a concern with chimneys than TYPE of wood. Although certain types of wood lends itself better to inconsistent flue temps: wet and/or most softwoods start slowly (low heat), then find it's heat cycle (high heat), and shortly thereafter smolder (low heat). You can have creosote problems with even the best seasoned wood if you don't burn properly...
    That's about 100 times more than I knew about that stuff. Thank you
    just get a pellet stove sav
    This isn't for my house. I do want a pellet stove. I have no time to do any research in brand/quality/installers right now due to holiday season
    Tell your buddy with the fireplace to get a pellet insert.
    That's one option. We still want to try the heat dispenser though
    My father is the only one I know that can coax real heat out of a fireplace. His has a heatilator, which I am sure helps.
    Ours made the house colder whenever we used it. I stuffed an insert in the fireplace. Wheymobettah.
    But best of luck with your research.
    fireplaces used to work cause they had a fire going in them all winter long, the thermal mass of the masonry is what radiated the heat
    Maybe.. but I think wood stoves have worked better since always.
  1. Wanted - Other | want firewood
    By tsorfas in forum Wanted
    Last Post: 07-14-15, 11:05 AM
  2. Free Firewood (VT)
    By Kitt in forum For Sale
    Last Post: 10-07-10, 08:51 PM
  3. Free firewood oak
    By Charlief in forum For Sale
    Last Post: 11-01-09, 03:48 PM
