Results 1 to 25 of 30
I want a light fast bike
    May 2011
    Holyoke, MA
    I'm interested in any bike you have that would be under 400lbs and over 100hp and somewhat comefortable. Bikes I've been eyeing are 2003-2005 r6 or R6S, 2001+gsxr 750, zx636, daytona 675, street triple 675, possibly an '04+ sv650 or monster 696. PM me with what you got.
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: I want a light fast bike
    I dont think any of those bikes are REALLY under 400# wet...
    and "light fast" is theoretically possible, might i suggest a delorean with an aftermarket flux capacitor.
    oh and your assumption that it has to be over 100hp to be fast is quite wrong...
    Keep it Kosher rsw81's Avatar
    Boston, MA
    I have a Street Triple R and am pretty happy with the power to weight ratio. As others have said, it's not the raw HP number you should be concerned with, but rather the way in which the power is delivered. Try looking more for flat torque curves more than peaky ones. Also a well balanced bike is better than a track ready street bike.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    all the current middleweights are just over 400lbs and over 100hp. so really you gotta get a little more specific with what you want.
    Banned G21forme's Avatar
    Lakes
    What's wrong with an 03 zx6r?
    Buy one of those two smokes that dude was selling on here.
    FS forum rules apply to the WTB section. Please keep this thread on topic.
    May 2011
    Holyoke, MA
    Guess there's nothing wrong with an 03 zx6r, just don't want a modern one or a zx6rr.
    You don't need 100hp to be fast, but it does make it easier.. .. I could probably be convinced to purchase an SV650 or Monster 696 if the right deal came along. But wouldn't go so far as to go to an overweight ninja 650 or fz6, or under 75hp GS500 or Ninja 500 or 250. Just my preference.
    To be more specific I want a fast light bike that is also decently comfortable. The only bike that is on my list that I haven't tried out yet might be the Daytona 675 which may be too uncomfortable for me. I've deffinately ruled out the newer zx6r's(07+) and the newer R6's(06+).
    Under 400lbs dry will fit the bill.
    Lifer JohnnyV's Avatar
    Westborough, MA
    You're current ride is an '03 Daytona, correct? I'm not seeing how your current ride is not already meeting your demands. Sure it's 20lbs over the weight limit but according to specs it is also 47hp over as well.
    2003 Triumph Daytona 955i
    Specifications
    ENGINE
    Type Liquid-cooled, DOHC,
    in-line 3-cylinder
    Capacity 955cc
    Bore/Stroke 79 x 65mm
    Compression Ratio
    12.0:1
    Fuel System Multipoint sequential electronic fuel
    injection
    Ignition Digital - inductive type - via
    electronic engine management system
    TRANSMISSION
    Primary Drive Gear
    Final Drive X ring chain
    Clutch Wet,
    multi-plate
    Gearbox 6-speed
    CYCLE
    PARTS
    Frame Tubular, fabricated aluminium alloy
    perimeter
    Swingarm Single-sided, aluminium alloy with
    eccentric chain adjuster
    Wheels Front Alloy 3-spoke, 17 x
    3.5in
    Rear Alloy 3-spoke, 17 x 6.0in
    Tyres Front 120/70 ZR 17
    Rear 190/50 ZR
    17
    Suspension Front 45mm forks with dual rate springs and
    adjustable preload, compression and rebound damping
    Rear
    Monoshock with adjustable preload, compression and rebound damping
    Brakes Front Twin 320mm floating discs, 4 piston calipers
    Rear Single 220mm disc, 2 piston caliper
    DIMENSIONS
    Length 2072mm (81.6in)
    Width (Handlebars) 725mm (28.5in)
    Height
    1165mm (45.9in)
    Seat Height 815mm (32.1in)
    Wheelbase 1426mm (56.1in)
    Rake/Trail
    22.5°/78.7mm
    Dry Weight 191kg (420lb)
    Fuel Tank Capacity 21 litres (5.5 gal US)
    PERFORMANCE
    (Measured at crankshaft to
    DIN 70020)
    Maximum Power 149PS (147bhp) at 10,700rpm
    Maximum Torque 100Nm (74ft.lbf) at 8,200rpm
    Warranty 2 years, unlimited mileage
    Service
    Intervals 6000 miles or one year, whichever comes first
    SV's are only 3-4 seconds slower than 600,750,and 1000 at Loudon.
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Lakes
    I was kinda kidding, 03 and 04 zx6r's are the same bike but with different colors. I'm not sure what mine weighs as you can never believe anything other than a scale but I ditched the stock exhaust so she lost a whopping 5 pounds maybe but puts down 104 to the rear and can be found for a good price.
    May 2011
    Holyoke, MA
    My '03 triumph weighed around 475lb wet and it was too tall and top heavy for me. It tracked solid and was a decent handling bike, but I wanted something more nimble.
    Ended up getting a '07 gsxr 750. It's got almost the same crank HP(not nearly as much torque or as nice a curve though) as the triumph but it's like 60lbs lighter and lower to the ground. The seat is also more comfortable than the '03 triumph. The newer speeds look really comfortable, the guy I bought the 750 from had a new speed triple(nice bike), but those are alittle out of my price range.
    Two many 2 strokes
    Bradenton FL
    how about 280lb and 115hp... get a 2 stroke and be done with it...
    I want a light fast bike-rs500_side9-jpg
    Lifer DuncanMoto's Avatar
    Quote Originally Posted by DynoTune View Post
    REALLY?
    115?
    Quote Originally Posted by DuncanMoto View Post
    REALLY?
    115?
    115hp with a WIDE power band even.
    I hate you for posting that. Such an amazing looking bike. And the worst part is I know it performs just as good or better than it looks.
    Two many 2 strokes
    Bradenton FL
    LOL, once he starts with a light bike with nice power he will never want to ride a fat bike again. Get an rz350, mod it and hang on! You will never look back... Seriously, check them out!
    I don't have that kind of $$$ to spend on a bike I would only ride short distances. I do have my own 2 stroke street legal bike in the works though...
    Two many 2 strokes
    Bradenton FL
    See....light and fast.... welcome to the dark side
    My goal is 210 lbs wet and 38 RWHP.
    Member RGB500's Avatar
    Feb 2010
    Connecticut
    You need one of these!
    What is that?
    Feb 2010
    Connecticut
    `79 RG500MK5
    Bridgewater, MA
    I highly doubt that aprillia is putting out 115hp
  1. fast bike, 200hp
    Last Post: 05-05-08, 08:08 AM
  2. Fast Bike
    By Nikon in forum General Bike Related
    Last Post: 06-28-06, 03:33 PM
  3. Got a new GO fast goodie for the bike
    By Sidewinder in forum General Bike Related
    Last Post: 09-27-05, 04:25 PM
  4. How fast will my bike go if....
    Last Post: 03-15-05, 05:34 AM
  5. I like them light and fast......
    By RevHappy in forum General Bike Related
    Last Post: 10-29-02, 03:18 AM
