I'm looking for a 20mm axle 21" front dirt wheel for a KTM, aka 00 to 02 fitment. A stock dirt brake setup would be handy as well, caliper, line, master, etc.
I also need a clutch slave, if someone has a complete Brembo setup (Dot3 based) that'd be nice, otherwise just a Magura slave will do the job.
I have a dirt wheel setup with front brakes. Brembo master, stainless line, brembo caliper, HH pads, etc. Wheels are from an SX, so they have Excel rims, not the Suns the EXC came with. Rear doesn't have a brake rotor but has the trick ((Enduro Emgineering?) wheel spacers. Would prefer to sell as a set. An interest?
That sounds perfect, pm me a price and I'll see what I've got in the change jar! : )
(That is a small axle front wheel, yes?)
If you were running it with 03 or newer forks, those are 26mm. There are reducer kits from KTM so you could use a 20mm axle in that setup, but I bet you'd remember doing so. On the flip side, if it was an 03 or newer wheel, and you used it on an 00 to 02 set of forks with a 20mm axle, you might have a set of aftermarket spacers to allow such a trick, in which case I'm even more interested. : )
Actually, if it's an 03+, and you have the stock spacers, I could just pester to get you to make up a set of adapters... same dimensions as stock, just drill the ID for a 20mm axle instead of a 26mm. Include a 26mm OD spigot for enough distance to go into the bearing, and past to keep the internal spacer between the bearings in place? Basically a 'captive spacer' style conversion, even though the seals essentially do that trick as is.
Still looking for parts for my kaboom so I can dirt convert it
20mm axle front dirt wheel
front dirt brake system, caliper/master/etc
Magura clutch slave or Brembo clutch master and slave
