Results 1 to 11 of 11
WTB: EX500 shock and fork springs.
    Lifer Expat's Avatar
    Mar 2007
    WTB: EX500 shock.
    Any racers got a decent rear shock lurking in the corner of their garage?
    My son has an 05 EX250 and I am wanting to stiffen up the suspension a little to improve handling. He is only about 110lbs so I don't need aftermarket stuff.
    Doesn't have to be pretty as long as it is functional. Cheap is the key!!
    Massive thanks to Christian for hooking me up with fork springs!!
    Re: WTB: EX500 shock and fork springs.
    36mm forks?
    Mar 2007
    36mm forks?
    No idea, stock 05 EX250 but I will check!
    Quote Originally Posted by Expat View Post
    Ahh ok...if they are stock my EX500 springs won't fit.
    Mar 2007
    I read online that the EX500 springs fit, I pasted the article below.
    If you are reasonably lightweight (check the Race Tech calculator) the Ninja 500 front fork springs from '94 and newer bikes might stiffen up your front end quite nicely for a bit less than the Racetech springs. The spring rate for these is .585 kg/mm (stock is .440); stiffer than stock, less than what the aftermarket companies usually make. EX500 springs are 28 mm diameter and 435mm relaxed length. Part number is 44026-1555, and they cost $33 each from Ron Ayers. So for $66, you get a much better front end feel.
    I will check the tube diameter.
    If the 500 springs will fit I have 3 sets of forks that you can have. 1 has aftermarket springs that are stiffer, and the other 2 have stock springs afaik. I also have a set of EX500 fork seals if you need a set.
    Mar 2007
    Wow, shoot me a PM and let me know how much you want. No spare rear shock?!!
    Central MA
    Here is an amazing list of axle sizes, fork tube diameters, etc.:
    http://www.clubchopper.com/forums/me...diameters.html
    Mar 2007
    That is great information, very useful! I saved it as a word doc. Thanks!
    Mar 2007
    I have some forks courtesy of csmutty so just looking for a rear shock now.
    Thanks!
    Mar 2007
    Bump!
  1. How do I select the correct fork springs??
    By jwm2k3 in forum Pit Area
    Last Post: 05-23-15, 06:19 AM
  2. Replies: 15
    Last Post: 09-17-14, 09:43 AM
  3. SV fork springs to try out
    By Rada in forum General Track Day Talk
    Last Post: 04-30-11, 07:16 AM
  4. Diverse fork springs
    By Fast_Eddie in forum Dirty Bastards
    Last Post: 04-18-11, 03:22 PM
  5. K6 GSXR fork springs?
    By Qfactor in forum General Bike Related
    Last Post: 01-18-07, 03:14 PM
