Results 1 to 10 of 10
SV650 Petcock/Filter
    Nov 2007
    Anyone got a mint one of these? Mine is OK I think but has some paint on it... would like to swap it out and OEM cost is a bit high. Looks like the attached.
    Attached Thumbnails Attached Thumbnails SV650 Petcock/Filter-capture-jpg
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Re: SV650 Petcock/Filter
    I would replace it with a Pingel one....never have to again
    http://www.pingelonline.com/prodcat/fuel-valves.asp
    Shawn perfers "The Guzzler"
    http://www.pingelonline.com/prodcat/...uel-valves.asp
    May 2010
    Somersworth, NH
    I replaced the petcock on my Gen1 (which is for sale BTW) with an oem replacement from BikeBandit.com. my petcock leaked and allowed the carbs to flood before filling over into my bellypan. I rebuilt it and it happened again. Replaced it completely and it hasnt happened since. dont get it why the rebuild didnt work but oh well.
    Nov 2007
    that pingel shit is pricey.
    brian you mean it leaked after you used the oem replacement? Or the replacement was fine?
    They list it at bikebandit at 90 bucks, around what I found it for in other places. A bit steep for a petcock. I figured someone might have one on a spare tank sitting around that they wouldn't need.
    LRRS/CCS #103
    Nov 2007
    Word? Guess I can just suck it up and buy OEM for 80 bucks... I would have thought someone had one kicking around on a spare tank though...?
    LRRS/CCS #103
    I have a spare.. but it's in use on the spare tank.
    I've rebuilt 2 gen-1 petcocks using the cheap rebuild kits on ebay. Never had a problem. Both rebuilds work fine now.
    If you're really anal get a manual cutoff switch and pipe it between the petcock and the fuel "pump". I did this for a while and would turn it off when stored. After a while I started trusting the petcock again and removed it.
    I've seen some nifty quick-disconnect fittings that seal when disconnected too.
    Although I'm not sure why you care if it has some paint on it.. So what?
    Nov 2007
    The screen/filter (piece sticking up in that diagram) is what has some paint on it. This reduces flow and if things start to get gummed up, it will clog sooner than if that screen was in good shape.
    Since that screen/filter tube is not able to be removed, at least that I can tell, without breaking it, then replacing the whole unit is the solution.
    I could cut that filter/screen off entirely, as I installed an in-line filter for a second line of defense, but ideally would not do so.
    LRRS/CCS #103
    Ah. I thought maybe you meant overspray on the outer part.
    Carry on.
    There are several on fleabay around the $40 mark.
    There is also this.
    Nov 2007
    Carry on.
    There is also this.
    I saw that. It looks like it is attached to an aftermarket unit, so unsure if the OEM is actually modular. I've tugged on the filter on mine as hard as I dare without ripping it off, and wouldn't do so harder unless i knew I had a backup unit. So either way I'm probably in for a new unit... then can try replacing the current unit's filter a little more aggressively and if I break it, then NBD.
    LRRS/CCS #103
  1. K&N X-Treme Motocross air filter vs. Foam filter?
    By Ductard in forum General Bike Related
    Last Post: 07-14-15, 01:05 PM
  2. switching from vacuum to manual petcock
    By breakdirt916 in forum Bike Maintenance
    Last Post: 08-20-13, 08:25 PM
  3. ex500 gravity petcock
    Last Post: 11-24-09, 01:37 PM
  4. Petcock on or off?
    Last Post: 12-13-07, 08:58 PM
