Results 1 to 15 of 15
WTB 14mm brake master for SV650
    Anybody have a 14mm bore brake master to fit 7/8" clipons for my 1st gen track SV? Any make or model would probably do, preferably with lever and reservoir to make it an easy swap. No idea what's on there now, says 5/8" on it. It takes a fair amount of effort to pull, without much feel. Input, suggestions, ideas all welcome!
    Re: WTB 14mm brake master for SV650
    14mm? Why so small?
    I run a 19x18mm Accosatto.
    Expert Agitator
    Ashford, CT
    You do realize that 14mm is smaller than 5/8" right?
    14mm? Why so small?
    Radial masters use a different linkage, the leverage ratio is greater allowing a larger bore. If you would like to donate your blingin' Awesomosatto master to my cause I will change my mind on the stock type 14mm...
    Quote Originally Posted by GearHd6 View Post
    Uh, yeah. A smaller bore master creates more pressure with less volume, just what I'm looking for regarding more braking force with more feel. But I'll trade you if you think bigger is better here!
    Just buy a Brembo 19RCS......or use a GSXR radial from a 09 1000.
    Here....................... http://www.ebay.com/itm/2011-2012-Su...583344&vxp=mtr
    +1 for the GSX-R radial master. My SV had one on it when I bought it. It worked great and is now my spare MC. (ask Adam, aka Rada how it works, since he had a chance to race with it when he shattered his during one round of racing)
    Like Pete, I now use a 19x18 Accossato radial.
    Btw. I don't think the sticker is 14mm. Never heard of a master that small.
    any 05+ GSX-R 600/750/1000 will fit your bike.
    it's usually around $50 used for one.
    Thanks for the replies guys! I am leaning toward the radial GSXR route, found an unmolested 2011 on evilbay. Will I need different lines? It looks like the banjo is straight down, mine is straight out.
    Be aware... The Nissin radial units found on most GSXR's can be a crap shoot. Some units are great and give a firm lever. Others are squishy and don't give much feel. It'll still stop great but you may never get a firm lever out of it if you get a squisher.
    You may want to consider a stock 16x18 Brembo off an r1 or r6
    The Daytona branded Nissin radial I ran on my GS was a 14mm. I've got 13mm and 12mm conventionals on my dirty derived toys...
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    +1
    I'll be relegating my Nissin to back up over the winter and buy a Brembo or Accossato. My Gixxer Nissin has lot's of power and crap feel.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    maybe, maybe not. depends how long your lines are
    Pepperell, MA
    I have a spare Stock Master I can sell u cheap. even a complete rear brake system.
    www.tailofthedragon.com
    Quote Originally Posted by Half Squid View Post
    Thanks, all set with a radial Nissin now.
  1. Replies: 17
    Last Post: 05-30-12, 01:54 PM
  2. WTB: front brake master cylinder
    By lopycam in forum Wanted
    Last Post: 08-08-11, 09:46 AM
  3. Front brake master cylinder
    By Ryno in forum Wanted
    Last Post: 07-27-11, 10:28 PM
  4. YZ/WR or YZF front brake master cylinder
    Last Post: 06-03-10, 08:41 AM
  5. 12mm brake master
    By Kurlon in forum Dirty Bastards
    Last Post: 05-03-10, 08:32 AM
