Results 1 to 20 of 20
Dyno-Bead Tire Balancing
    Superhero F4Iguy's Avatar
    Vermont
    I just decided to try the new Dyno-bead tire balancing system, vs. the typical wheel weights. anybody else try these, notice any differences? Obviously I haven't gotten to ride it yet, just wondering what to expect.
    What?
    Jun 2005
    Re: Dyno-Bead Tire Balancing
    Is that like that Equal sand stuff truckers use? If so I tried it in a set of 33" truck tires. My review is that it sucked. Big bags of Portugese dicks.
    Just Registered Doc's Avatar
    Jericho, VT
    Quote Originally Posted by F4Iguy View Post
    Are you serious? Never heard of it.
    Junior Member youngblood's Avatar
    I searched a few forums and can't find anyone that has used them. On the dyna bead site they explain how it works well for motorcycle tires and not for wider car or truck tires. I wonder if it really works?
    Well...I think I will stay with the stick-on weights.....
    The way we do this is by offering a Dynamic Balancing Solution, a high-density ceramic bead that, when easily installed, continuously balances your tires as you drive. The amount of material will distribute itself in weight and position dependent on the balance requirements of the individual tire.
    Whats wrong with old Way?
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Don't go near that stuff.
    That's coming from a guy that mounts and balances hundreds and hundreds of bike tires a year.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Ive even talked to people who say ya don't need ta bal. bike tires..
    I still do mine....
    www.bostonmoto.com
    Forum Rules
    Uxbridge, MA
    I tried them last year, I saw NO advantage/disadvantage to them at all.
    I really doubt they did a thing.
    I usually don't ballance my tires and have not had a problem......yet.
    Don't mean I shouldn't I just did not have a balancer and I change my own tires...
    They never wobbled before them, nor after they were installed.....
    I still have a good size bag of them if someone want to try them or see if they even work....try them on a tire that is WAY off.....be interesting to see, maybe?
    KB KB's Avatar
    Manchester NH
    I do not know about that shit but I do not balance any of my bike tires either.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Dec 2003
    Ma
    +1
    Especially on the track, one session on the tires and the balancing is out the window anyways.
    Those beads can only correct imbalances in very specific scenarios which don't occur with motorcycles.
    Lifer DuncanMoto's Avatar
    Degsy, don't they put balance marks on the tires from the factory showing how to place the tire on the wheel for the closest balance?
    I too never balanced tires until I had a front wheel wobble at 85mph. It was a consistant wobble anytime I hit 85. It didn't do that when the tire was new, but after 8,000+ miles of mostly commuting to Western MA on route 2, this developed. I took it to a dealer who balanced it and put weights on it and it was fine after that. Now I have all my tires and wheels balanced every time.
    Lifer union's Avatar
    Blackstone, MA
    Quote Originally Posted by DuncanMoto View Post
    Some companies do and others dont. I know Michelin doesnt put a mark on its tire. The way they are manufactured they dont typically have a heavy spot. Ive had sets that have needed no weights. Dunlop puts a yellow mark on their tires and that goes at the valve stem.
    James
    Meriden, Ct
    I'm not advocating their use. And I'm certainly not putting 3 ounces of additional material around the outside circumference of my wheels but, I came across this. Figured I'd post because it was the topic of discussion.
    http://www.evolutioncycles.com/dynabeads.htm
    I have nothing better to do so I spend an hour balancing my own tires to minimize the addition of weights.
    Worcester, MA
    Any spreadsheets to back that up?
    LRRS EX #165 (formerly)
    Quote Originally Posted by BMFR6 View Post
    don't make me go there. You know I will if I have to.
    High maintenance priss
    Central MA
    Thanks for posting; i was also interested in opinions too. I bought a second set of rims for my TL & they have dynabeads installed; i was fairly skeptical when i read up on them. Mostly about how quickly they balance, how fast the wheel has to spin and leaning of the tire.
    The guy i bought the rims from said his shop has used them for 2 yrs w/ great success. I'll let you know once spring rolls around.
    Degsy - Care to share reasons why you don't like 'em?
    KB KB's Avatar
    Manchester NH
    Big bags of portugese dicks...................Now that's a new one, and I like it very much!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Replies: 0
    Last Post: 09-02-13, 04:21 PM
  2. tire mounting/balancing
    By darkduc7 in forum Vermont Events
    Last Post: 06-21-10, 09:15 PM
  3. WHO?: Tire Mounting and Balancing
    By Suf Daddy in forum General Bike Related
    Last Post: 07-16-06, 09:31 AM
  4. Tire balancing...
    By Tricky Mike in forum Bike Maintenance
    Last Post: 06-12-06, 01:03 PM
  5. Tire Balancing
    By KB in forum Bike Maintenance
    Last Post: 05-04-04, 07:20 AM
