can you swap pads in a Shark to get a tighter fit? I have an RSR2 and it fits nice but could be a bit snugger like my Suomy.
LRRS Am #331
My understanding is that they make the RSR2s in two shell sizes, which probably means that you can get different pad sizes.
s/m and l/xl are the same size shell as far as i know in them, so you can switch the inner lining to a smaller one given you have the larger size in it
- TJ
LRRS Am #331
Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
Not exactly.
Pull your pads out and read how many mm they are.
LRRS Am #331
Talk to Noel he used to be a Shark dealer.
I love my shark. It was under 250 and I like the fit better than any other brand I have ever owned.
http://www.revzilla.com/product/shark-rsr-2-cheek-pads
I believe you can get an XS set of pads that should make it tighter, If you can find a supplier who has them in stock.
+1 I believe you can get XS cheek pads. I miss my old shark
