Hey guys just wondering if the AGV helmets are Snell or DOT approved for 2011. And which ones are the new helmets for 2011 tht I can use this yr for the track. Thanks guys.
A simple search for "2011 AGV helmet safety certifications" turns up the following information:
Helmet Model: GP-Tech
Helmet Sizes: XXS - XXXL
Helmet Certifications: ECE 22-05, DOT
Helmet Weight: 3.44 lbs (1560 grams)
Helmet Model: S-4
Helmet Sizes: XS - XXL
Helmet Certifications: BSI, DOT
Helmet Model: K3
Helmet Model: Stealth
Helmet Weight: 3.39 lbs (1536 grams)
Helmet Model: T-2
Helmet Certifications: EC 22-05, DOT
Helmet Weight: 2.87 lbs (1300 grams) Estimated
Helmet Model: Ti-Tech
Helmet Weight: 3.49 lbs (1582 grams)
Helmet Model: XR-2
Helmet Weight: 3.62 lbs (1645 grams)
No prob.
Sorry it copied all crazy but from the 2010 LRRS rulebook (because I could not find the 2011 rulebook)
"HELMETS: Helmets must be full coverage with an attached face shield. Tearoff's are not allowed. Quick release helmet straps are also not allowed unless original equipment. The helmet must meet DOT plus Snell M2005 and
M2010(USA) approval or the British Blue Label standard BSI 6658 Type A
helmet standard or the European ECE22-04 & ECE22-05 P standard. The
appropriate stickers must be attached. Any helmet that has been damaged or
suffered a severe impact must be replaced or sent to the manufacturer to be
inspected. All helmets must pass tech inspection. The riders number must be
displayed on the helmet.
Helmets may not be more than 5 years old as determined by the date of
manufacture in or on the helmet. Polycarbonate helmets are not allowed."
The K3's are plastic. I don't think they will pass tech. Get a Stealth.
Sorry guys for not doing enough research before posting. Thanks for the help.
Thanks, i ended up getting a AGV XR-2
Little problem. Got the XR-2 in the mail today and found out tht the production date is 07/05. But the thing is the most comfortable helmet I have ever tried.
That is probably why you got it cheap...
You need to get a newer helmet to pass tech.
This is exactly why I go to Duncan Moto. I get a proper fit from Mrs. Duncan on the freshest lids from Mr. Duncan.
