The Ninja 400 is THE bike to be riding in the 2018 season! We have been busy developing parts for it over the last few months with nonstop development for this bike!
Happy to report we have a myriad of new products ready to rock for your Ninja 400:
Hindle Exhaust
Hindle made some fantastic systems for the Ninja 400. How good? They've already won a Moto America Junior Cup Race! We should have stock of these in our next shipment so if you have your hands on a 400 make sure to get some hands on these Hindle systems before they are gone!
Slip-Ons Starting at Just $214.99!!
Full Systems Starting at Just $474.99!!
We'll be carrying the full system in both EVO and EVO Megaphone as well as Slip-On EVO and EVO Megaphone systems. The EVO system will come in four variety of canisters: carbon with carbon tip, titanium with carbon tip, ceramic black with stainless tip and brushed stainless steel with stainless tip. The EVO Megaphone will come with your options of stainless or carbon tip (pictured below).
Rearsets
These complete rearsets feature:
+6061-T6 billet Aluminum construction
+3-Piece pedal assemblies
+12 position adjustable eccentric footpegs
+Knurled foot pegs for optimum grip
+Integrated shift heel guard
Complete Rearset Kits Starting at Just $449.99!!
This kit is designed for the new Ninja 400 to give you the optimum foot position and ground clearance for racing. This kit is custom tailored for Ninja 400 and our adjustability allows for the perfect position - race or street. Our rearsets have proven their worth with hundreds of national and regional championships since 1996. This kit offers adjustability from 25 to 50mm up and 35 to 54mm back and features Woodcraft's classic durable design!
Engine Cover Protectors
Woodcraft 2-piece engine covers are designed to keep your bike oil tight in the event of a crash as well as to give your bike a custom look that will make you stand out in the crowd. All of our covers are 100% CNC machined from 6061 Aluminum billet to give you both great looks and exceptional strength.
We've added a rubber pad adhered to the inside to provide a cushion between the cover protector and the stock cover - details that set Woodcraft apart from everyone else!
The patented replaceable stainless or aluminum skid plate adds wear resistance in the most vulnerable area and can keep your cover both functional and looking good through multiple crashes. The plate is internally bolted so that you don't have to worry about trying to remove bolts with the heads ground off.
Note: These are an engine cover protectors. They bolt over the OEM covers in minutes, protecting the portion that is most vulnerable in a crash.
Kawasaki Ninja 400 Clutch Cover Protector Just $129.99!!
Kawasaki Ninja 400 Stator Cover Cover Protector Just $149.99!!
Clip-Ons
Woodcraft is proud to present our Ninja 400 clip-ons. We worked hard to develop a set of clip-ons to fit this bike perfectly. A simple re-positioning of the brake line is necessary on this model. Installation requires no cutting or permanent removal of parts. The Ninja 400 clip-ons feature a 2 1/2" riser that eliminates interference issues with the bodywork and fuel tank, while getting the bars as low as possible.
Woodcraft 2-piece split clip-ons are specially designed to make installation and removal a snap. Our 2-piece design is race proven and makes it easy to service your clip-ons below the triple clamp without having to disassemble the entire front end.
Kawasaki Ninja 400 Complete 41mm Clip-On Kit with Bars Are Just $184.99!!
Frame Sliders
Woodcraft has two new frame slider options for the 2018 Kawasaki Ninja 400. Our street kit is a "no cut" version and the race kit is designed to be used with aftermarket bodywork. Both of these kits feature the Woodcraft patented slider pucks, which utilize our tried and tested low friction plastic and trademark perpendicular attachment bolt. These pucks last longer, slide smoother and are easier to replace than any other puck on the market. Both kits have an incredibly solid mounting base that will help ensure that these parts do their job! Our race kit is virtually indestructible and the offsets on the street kit utilize a special anti rotation setup that will help keep everything in place in the event of a crash. As with all Woodcraft products, each individual piece of these frame slider kits can be purchased separately or as spares.
Kawasaki Ninja 400 Race Only Frame Slider Kit (Pucks Included) is Just $89.99!!
Kawasaki Ninja 400 Street Only Frame Slider Kit (Pucks Included) is Just $119.99!!
Kit Photos Side By Side (Left Race, Right Street)
Installed Side By Side (Street Left, Race Right)
Keyswitch Eliminator
Our Keywwitch eliminator lets you remove your stock ignition switch saving weight where it counts - up high! Removing your stock ignition will also free up valuable space for steering dampers and lap timers. The things you need go in the space you save. The best thing about our Key Switch Eliminator is the ability to simply "Plug and Play". It installs in seconds and requires no modifications to your stock harness - no need to cut any wires! This means easy re - installation of stock components down the road.
Kawasaki Ninja 400 Keyswitch Elimination Harness Are Just $54.99!!
