sheet rocking around windows?
Hey all, I just put a drop ceiling in the basement of my parents house, the thing is the walls aren't finished yet. I brought the edges of the ceiling out an inch with 1" by 4" wood strips so I could sheet rock the walls after the drop ceiling was done. My question is, How close to the windows to sheet rock?? do you go right up to the frame and put molding around the window? or do I need to leave space between the window frame and the Sheet rock? In other words, do I need to frame the sheet rock larger than the window frame or do I put the sheet rock right up to/against the window frame? Thanks:dunno:
I've always put the rock right up to the window, leaving about 1/4 - 1/8 inch for ventilation, then put the trim on. :dunno:
sheet rock right over it then cut it out
If your windows are in (which I'm assuming they are) they should protrude past the framing the thickness of the drywall or less then you drywall up to the window frame leaving enough space for expansion. It doesnt matter a whole lot just as long as your trim will cover it.
The real question is Why would you put in the suspended ceiling first? You left 1" from the wall to put the drywall up behind it? if you did there will be a 1/2" gap if you're using 1/2" drywall.
Don't forget to insulate the walls first even if it's concrete you will still lose heat.
make sure you have a hand when purchasing it because that shit is heavy.....
5/8" drywall, + 1"x3" ferring = 1"3/8"..your are going to cover some of the grid, if you only padded 3/4"
I did my sheet rock first in teh basement, now playingwith teh ceiling and the wonderfull world of "Crown Molding" Thank God for the compound miter saw...:axe:
Quod Erat Demonstrandum
Put the sheetrock against the window and rotozip around it. Leaves a perfect 1/8" gap and a shitload of dust, but takes almost no time, measurement or effort.
Read the directions on the rotozip! It is easy to make a mess. Going around a window, you need to move the tool counter clockwise since you are resting the guide bit against the outside frame of the window. When cutting a hole for an electrical box, you rest the bit against the inside of the box and must go clockwise.
From the manual:
"When routing or cutting, the direction of
feed with the bit’s cutting edge into the
material is very important. Always feed
the bit into the material in the same
direction as the cutting edge is exiting
from the material. When viewing the tool
from the top, the bit rotates clockwise. If the
tool is between the workpiece and you body,
then feed the tool to your right. If the
workpiece is between the tool and your body,
then feed the tool to your left. Feeding the
tool in the wrong direction causes the cutting
edge of the bit to climb out of the work and
pull the tool in the direction of this feed."
Wear a dust mask and googles.
If you can avoid using 5/8", do so. It is absurdly heavy. Do you have to use it for your local building code or something?
