Results 1 to 17 of 17
sheet rocking around windows?
    Jun 2005
    Hey all, I just put a drop ceiling in the basement of my parents house, the thing is the walls aren't finished yet. I brought the edges of the ceiling out an inch with 1" by 4" wood strips so I could sheet rock the walls after the drop ceiling was done. My question is, How close to the windows to sheet rock?? do you go right up to the frame and put molding around the window? or do I need to leave space between the window frame and the Sheet rock? In other words, do I need to frame the sheet rock larger than the window frame or do I put the sheet rock right up to/against the window frame? Thanks
    Littering and........
    Jul 2004
    Vermont
    I've always put the rock right up to the window, leaving about 1/4 - 1/8 inch for ventilation, then put the trim on.
    Jun 2005
    sounds good
    Thanks for the knowledge.
    sheet rock right over it then cut it out
    Mar 2004
    woonsocket ri
    If your windows are in (which I'm assuming they are) they should protrude past the framing the thickness of the drywall or less then you drywall up to the window frame leaving enough space for expansion. It doesnt matter a whole lot just as long as your trim will cover it.
    The real question is Why would you put in the suspended ceiling first? You left 1" from the wall to put the drywall up behind it? if you did there will be a 1/2" gap if you're using 1/2" drywall.
    Don't forget to insulate the walls first even if it's concrete you will still lose heat.
    Jun 2005
    i wanted to get the ceiling out of the way first because theres a SH#@ load of stuff thats blocking most of the walls since the basement has served as a storage area for my folks. About the sheet rock, I'm going to use 5/8ths sheet rock and ferring strips if neccessary when I put up the sheet rock.
    Senior Member MnM's Avatar
    Apr 2005
    Central MA
    make sure you have a hand when purchasing it because that shit is heavy.....
    Posting Freak Ecooke21's Avatar
    Oct 2002
    North Providence
    5/8" drywall, + 1"x3" ferring = 1"3/8"..your are going to cover some of the grid, if you only padded 3/4"
    Current Toys:
    2005 Nissan Titan CC
    Resident Chrome Dome Cue Ball's Avatar
    Johnston, RI
    I did my sheet rock first in teh basement, now playingwith teh ceiling and the wonderfull world of "Crown Molding" Thank God for the compound miter saw...
    All I want for Christmas is another rear tire.....
    http://www.ratemythong.com/indexhome.php
    Lifer ZX-12R's Avatar
    Candia, NH
    Quod Erat Demonstrandum
    Raymond NH
    Put the sheetrock against the window and rotozip around it. Leaves a perfect 1/8" gap and a shitload of dust, but takes almost no time, measurement or effort.
    Read the directions on the rotozip! It is easy to make a mess. Going around a window, you need to move the tool counter clockwise since you are resting the guide bit against the outside frame of the window. When cutting a hole for an electrical box, you rest the bit against the inside of the box and must go clockwise.
    From the manual:
    "When routing or cutting, the direction of
    feed with the bit’s cutting edge into the
    material is very important. Always feed
    the bit into the material in the same
    direction as the cutting edge is exiting
    from the material. When viewing the tool
    from the top, the bit rotates clockwise. If the
    tool is between the workpiece and you body,
    then feed the tool to your right. If the
    workpiece is between the tool and your body,
    then feed the tool to your left. Feeding the
    tool in the wrong direction causes the cutting
    edge of the bit to climb out of the work and
    pull the tool in the direction of this feed."
    Wear a dust mask and googles.
    Raymond NH
    If you can avoid using 5/8", do so. It is absurdly heavy. Do you have to use it for your local building code or something?
    Jun 2005
    5/8
    Naa, THe reason I gotta use the 5/8ths is because I put the drop ceiling in first and mounted the perimeter of the ceiling to leveled 1 by 4 strips of wood so I could try and finagle the sheet rock afterwards. I did this hoping that I could have the sheet rock neatly butt up against the ceiling without protruding over the the edges of the drop ceiling( the L type brackets around the perimeter of the ceilng). If I was smart about it I would have finished the walls first but I had a limited amount of time and wanted to get the ceiling out of the way. The ceiling came out great, I put some high hats in for the lights,,, now I gotta deal with trying to make the sheet rock look neat up against the ceiling.. any thoughts??
    Feb 2004
    Bellingham, MA
    Re: 5/8
    Yeah...don't quit your day job......
    Re: 5/8
    Take the ceiling down, put the dry wall up, put the ceiling back up
    They sell a finished edge you can slip over the sheetrock joint, it's like a J channel. Pad the wall out (you can even use 2" rips of sheetrock over the wall studs) and slip the J channel over the sheetrock edge and butt that edge upto the ceiling track
    As for the windows, I always like to leave 1/2" space for some insulation. If you don't insulate around your windows, don't waist your money on wall insulation
    Raymond NH
    Re: 5/8
    Go with 1/2" drywall and put up some molding like a miniature crown molding.
    Raymond NH
    Re: Re: 5/8
    Insulation needs to be in before the sheetrock goes on. That's a given.
  1. Rocking chair.
    By Rosco61 in forum Off-Topic
    Last Post: 12-08-13, 07:39 PM
  2. Anyone rocking Knox Handroids
    By slammp in forum General Bike Related
    Last Post: 01-16-11, 02:41 PM
  3. WTB: Verizon Windows Windows Mobile phone
    By schleppy in forum For Sale
    Last Post: 08-05-09, 02:50 PM
  4. Aluminum Sheet
    By tom5796 in forum Bike Maintenance
    Last Post: 09-19-08, 02:13 PM
  5. Sponser Listing Sheet
    By BMFR6 in forum Pit Area
    Last Post: 06-01-07, 07:58 PM
