Page 1 of 3 123 LastLast
Results 1 to 25 of 54
gauge LEDs
    Bikeless SmokennFasTT's Avatar
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    well Rob i took you advice and i took apart the gauge cluster on my RC to see if i can change the color.. and i must say i have never seen theese kind of LEDs before... now if i can just figure out how to take them off w/o hurting the board ill b all set.. anyone kno what theese square LEDs are called? i found a few of them(none that would work tho...) does anyone kno the MCD on them or direct me to were i can find out... it dident say in the book lol
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    03 XR400 R(TARD) - Sold
    gauge LEDs
    Are the little white squares the LED's?
    Resident Bosox Aficionado mikem317's Avatar
    May 2005
    gauge LEDs
    ^ Yup.
    Regards,
    Mike
    Where were you on October 27, 2004? // Got Wallpaper? // Special Discount for Boston Red Sox Fans! // Because even Alex Rodriguez has feelings too...
    "Everytime I see a Yankee's hat, I see a swastika just a little off kilter." -- Bill "Spaceman" Lee
    Lifer Punjistick's Avatar
    Norwell, MA
    gauge LEDs
    ask ZX-12R (Bill) he should be able to point you in the right direction.
    Lifer ZX-12R's Avatar
    Candia, NH
    gauge LEDs
    Those are surface mount LEDs. To remove them (assuming you don't have a hot air rework station) you will need a soldering iron, tweezers, and a solder sucker or solder wick.
    Heat one side of the LED and use the sucker or wick to remove as much solder as possible. Repeat on the other side. Next, grab it with the tweezers and lift gently while applying heat on one side. It should lift up a little bit. Once it does, keep pulling gently and apply heat on the other side, it should come right off.
    To get replacement LEDs you will have to search through catalogs like Digikey or Mouser until you find the size you need. Digikey has a very powerful parametric search which will let you search by package size. Unless you can get me measurements, I'm not 100% sure what size the LEDs are on that board.
    If you need more help, let me know. I can get you squared away.
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    awesome bill thx, quick question... so do i have to worry about burning the board and screwing it up? i have a 15 watt iron.
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Candia, NH
    gauge LEDs
    So long as you don't keep the iron in one place forever plus a day and a half you should be all set. As with all soldering, try and do it as quickly as possible. The traces on that board seem to be pretty heavy so you shouldn't have too much of a problem. Just remember to keep your tip clean.
    Another thing to note, if you switch to different color LEDs, you have to take into account the voltage drop across them otherwise they might not light up.
    What color are the LEDs that are installed right now and what color do you want to switch to? It might not be as easy as replacing them with a different color.
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    amber/orange/yellow? lol
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    u think its gona take that long to do? how much to buy one in a diff color? lol.. if its going to b to much of a hassle i might just leave it the ugly color it is.. i would like a blue or a red LED.. im prolly gona get 1/2 way into it and not finish it than have to buy a new one lol
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Winchester, MA
    gauge LEDs
    Careful about blue LEDs, without going into too much technical details blue LEDs have a higher voltage drop than the yellow LEDs that you'd be replacing with. You might need to change the current resistors as well in order to get the proper brightness (otherwise they will be too dim), or they might not work at all if they're being sourced with a 3.3 volt supply.
    Most red LEDs have a slightly lower voltage drop than yellow, so by swapping them out with red LEDs you might get slightly higher brightness (and correspondingly decreased lifetime) but the difference is likely to be fairly minor, yellow/red/green leds are *mostly* interchangeable without fiddling with the current resistors.
    As bill said, a soldering station with a pair of SMD tweezers makes it a whole lot easier to change out LEDs, we have one at work and I'd be willing to swap out the LEDs for you if you run into trouble.
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    i dont want to swap all the resistors, i want to make this as pain less as possible lol ill prolly get red than. i dont have any blue on my bike n e ways its just my fav color.. if i do run into problems how much is it goin cost me to have you swap em out? and do u kno a site when i can find some of thos LEDs? ive been lookin and i cant seem to find the ones that are on there.. thx alot guys -Larry
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Candia, NH
    gauge LEDs
    If you can measure the general dimensions of the LEDs with a pair of calipers, I can help you find the appropriate replacement LEDs through Digikey.
    May 2005
    gauge LEDs
    I hope this pans out. I want to see the final result!
    Regards,
    Mike
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    me2 lol
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Pepperell, MA
    gauge LEDs
    Do you mean like mine??
    Here is my advice, do what I did, bike the bike that already had it done!
    www.tailofthedragon.com
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    you suck.... your the whole reason im doing this because i saw how sick yours looked and i was envious of your speedo lol.. your think the blue looks good on the red bike?
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    and your about to have 6000 posts
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    gauge LEDs
    Smokenn, once you have this done, Id like to try to my 2003 RC...keep me in the loop.
    Lifer union's Avatar
    Blackstone, MA
    gauge LEDs
    Blue looks good. Wonder if you could do white.
    James
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    will do and ill tell u how much of a pain it is and if its worth it lol
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    does anyone kno a place around here that sells surface mount LEDs?? i dont want to want to get them online... help someone lol
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Candia, NH
    gauge LEDs
    You are SOL on that one. Try and find an electronics store first let alone one that sells surface mount stuff. They are very few and far between in this day and age.
    Why don't you want to order online? Digikey is a fantastic company to deal with. Ask any electronics dork out there including myself and they will tell you the same!
    What color have you decided on? Red should be pretty much a drop in replacement. If you want blue or white it will take a hair more work but is certainly not that difficult relative to just switching to red.
    Candia, NH
    gauge LEDs
    Hey Mike (Squid), is the backlight on your RC LED based or did the guy use electroluminescent film?
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    hey bill you got AIM or MSN?
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Apr 2006
    ManchVegas, NH
    gauge LEDs
    i dident want to order online cuz i dident want to wait lol.. i would like a RGB that would b kinda cool no? i really dident want red but it would match my bike.. i love blue.. and white would b cool.. im not sure, i dont want to have problems with it i just want it to work good and last..
    i got the measurments im MM's bill will that help?
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
  1. Changing turn signals to LEDs ... a problem ...
    By whynot in forum Bike Maintenance
    Last Post: 09-27-20, 04:30 PM
  2. LEDs and current draw
    By breakdirt916 in forum Bike Maintenance
    Last Post: 03-31-16, 10:50 PM
  3. anyone have a runout gauge?
    By scubasteveRR in forum Bike Maintenance
    Last Post: 01-22-10, 10:32 AM
  4. Should DBConz remove the LEDs on his gixxer
    Last Post: 08-15-08, 01:34 PM
  5. Pictorial comparison - red vs clear taillight, bulbs vs LEDs
    By Proulx06 in forum General Bike Related
    Last Post: 07-27-05, 08:49 AM
